Thread: Pegged Oil Level Gauge
    Question Pegged Oil Level Gauge
    My Oil Level Gauge was reading correctly without issues...until today.
    This morning I had the back of the car jacked up with the rear wheels removed so I could access the wheel wells to scrape away the loose and flaking spots of undercoating. The good news is that there are no signs of any rust or collision repairs. Just 36 years of dirt, grime, and grease build-up which was mainly located around the oil tank and its lines. I was able to get most of that cleaned up with an old paint brush and mineral spirits.
    With wheels back in place, and the car back on the floor, I fired it up and immediately noticed that the Oil Level Gauge's needle is now pegged all the way to the top....past full. I warmed it up to operating temp and then checked the oil level with the stick, and it's just below the stick's top mark.
    So, my question is, any ideas what may be causing the false reading at the gauge, and how I can fix it?
    thanks,
    Frank
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    You may have knocked the ground wire off it's connection on the oil tank. I think this would cause the false reading. Just check the wiring to the oil tank and try it again.
    HTH
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    Mar 2006
    Louisville KY
    Like mentioned above you probably knocked the wire loose and it is touching the tank causing the wire to go to ground which will cause the gauge to move to the full mark.
    Tony Proasi
    52 split window coupe
    ground wire off will peg it to the top/
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Thank You!
    Thanks for the advice guys...wire re-connected and the gauge operates correctly again.
    Now I just need to wash all of the crud out of my eyes
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    tears of joy from our good answers
  1. Replies: 3
    Last Post: 04-09-2014, 02:23 AM
  2. Wiring question / oil level gauge
    By ze german in forum Technical Info
    Last Post: 01-12-2013, 12:56 AM
  3. WTB - '67 oil level/fuel level gauge and screw on shift knob
    Last Post: 03-31-2011, 11:29 AM
  4. Replies: 3
    Last Post: 11-09-2010, 02:09 AM
  5. Oil Level gauge jumps
    By Bobs 67S in forum Technical Info
    Last Post: 10-23-2002, 09:44 PM
