Results 1 to 1 of 1
Thread: HCT kit, anything missing?
    I have these parts for upgrading to hydro. carrera tensioners. I will be using the old arms and chain wheels, I think I need some spacers since I will be using these? cant find them on pelican unless these are correct:
    930-105-513-00-M105
    I guess I will not need the pressure sender in the picture?
    Do I need to compress the tensioners and install the pin(that is pulled after install) or is this not the case with the carrera tensioners?
    What are the two small round alu. cylinders in the picture for, they are not 100% alike?
    Any parts missing?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
  1. 912 ID tag gone missing...
    By racer9007 in forum General Info
    Last Post: 04-18-2013, 04:35 AM
  2. What am I missing here ?
    By Mrzoop in forum General Info
    Last Post: 09-04-2012, 08:17 AM
  3. What part am I missing?
    By brseidel in forum Technical Info
    Last Post: 01-13-2008, 10:12 AM
  4. What am I missing here?
    By Max (SD) in forum General Info
    Last Post: 05-12-2005, 01:29 PM
  5. The missing link !
    By Rick Cabell in forum General Info
    Last Post: 02-06-2004, 04:31 AM
