Results 1 to 8 of 8
Thread: Transmission number mystery.
    Restoration newbie.
    Jun 2007
    San Francisco
    I'm looking for some help identifying my transmission as being
    correct to my car or not. The stamped serial number is 7191377,
    I did not yet locate the type number under all the grime.
    The issue I have is that the options list includes LSD. I have a feeling
    either the differential or the entire transmission has been changed
    out because the half shafts are LOBRO instead of the Nadella which
    should be installed for LSD.
    I spoke to Porsche and the bloke there says that the engine serial
    number (from the build sheet) should be 2xx.xx, seems a bit off to me
    from the other serial numbers I've seen so far but can anyone confirm
    what the serial number from a LSD transmission looks like? Maybe
    he's reading the wrong number, it's in German after all.
    All help appreciated.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    www.spyderautomobiles.com .au
    Feb 2005
    Australia
    Hi Andy,
    The number you have given is for a standard ratio 5 speed for model year 1969. The type should be 901/07 (when you manage to scrub off the grime ).
    Happy to look at the other numbers you have been given if you feel comfortable sending a pm.
    Cheers,
    Lisa
    Lisa Gregory
    Early 911S Registry #726
    www.spyderautomobiles.com.au
    Restoration newbie.
    Jun 2007
    San Francisco
    Thanks Lisa, I actually wasn't masking the number 2xx.xx, all
    that Porsche could give me was the first number. Understandably
    they are concerned that if they give the correct numbers then
    fake stampings of the correct numbers could be made.
    Any idea what the number 2xx.xx from the build sheet refers to?
    I've looked all over the boards and never seen a transmission
    number in that format.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Feb 2005
    Australia
    Andy,
    Using your chassis number (with no "s" stamped), the guys at Porsche may make the assumption that the car is a 911, not an S and most likely have assumed a 902/1 TM which has a number range 220 001 - 221 721. I don't believe there are 5 digit TM numbers. However, if they were to assume your car is an S produced in the '67 model year then it should have a 901/02 box if standard, number range 103 001 - 105 191. Both boxes are 5 speed, but the 902/1 has a shorter 5th (all other ratios are the same). It may be that the guys at Porsche are right -your car could have been ordered with a specific TM which contained a shorter 5th...or it could have been ordered with any ratio requested.
    Clear as mud isn't it ....
    Lisa Gregory
    Restoration newbie.
    Jun 2007
    San Francisco
    Well, things are becoming clearer. I think you're right, my car was ordered
    with the shorter 5th gear and got a 902/01 box. Must have been replaced
    sometime with this later transmission without LSD.
    Guess now I should start searching for a 902/01 or 901/02 to make it more
    original.
    I figured something was up when I spun one wheel and the other wheel
    spun backwards.
    Thanks for your help Lisa.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Feb 2005
    Australia
    Andy,
    I'm doing some lateral thinking for you...sending you a pm .
    Cheers,
    Lisa
    Lisa Gregory
    Restoration newbie.
    Jun 2007
    San Francisco
    The plot thickens ... considerably
    I have spoken with Porsche again and the very helpful chap there
    has confirmed that the number against the engine is 2xx.xx
    (that's no typo, just 5 numbers separated with a period) and
    that there is no other serial number against the transmission.
    He was able to get a translation from Germany as his german is
    pretty basic and it lists "Airport gears" against the transmission.
    Now, the money question, what should the serial number for a
    67S gearbox with airport gears look like?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Feb 2005
    Australia
    OK - well I would l think that the transmission type should be 901/52. Trouble is that I can't readily find all the papers we have with a list of TM numbers recorded against types . The spec books are no good for pre '68 for this type of info, as the TM serial numbers are not listed except for the most "common".
    I think we have some info recorded; but since we've moved everything I have to find where we've put it....
    C'mon guys - I know a few of you are lucky enough to have this combo in your cars...can anyone crawl under and read a TM number for Andy?
    Lisa Gregory
  1. Replies: 13
    Last Post: 10-28-2013, 03:42 PM
  2. Transmission number which one is right one?
    By ds58 in forum General Info
    Last Post: 09-24-2012, 09:30 AM
  3. Replies: 0
    Last Post: 09-09-2012, 04:29 AM
  4. WTB: Transmission carrier/mount for 911 (series) transmission
    By PeterM1965 in forum For Sale: 911 Parts
    Last Post: 07-02-2011, 08:16 PM
  5. Transmission 'Key' Number
    By gilbert911 in forum Technical Info
    Last Post: 11-15-2010, 12:59 PM
