Results 1 to 10 of 10
Thread: 1968 911 Normal fuel pump location
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    I have been restoring this car for a couple of years and am now down to the last couple things that haven't resolved themselves. When I began taking this car down, I wasn't too concerned with the location of the fuel pump (Hardi). It was located by the steering gear. The bracket was obviously home made and is not reusable since the aluminium is very fatigued where it was bent. My questions are first was this common to move the pump out of the engine compartment away from the heat? I am in Oregon and haven't had any vapor lock issues in my 912. Secondly, the power was pulled out of the first fuse location (stop light, blinkers) is this ok (if I put the pump back up front)? Thirdly, I am inclined to want to put it back in the engine compartment but I would need to find an original mount (E901.608.111.00 probably not a big deal) and would also like to see a picture of how the pump originally got its power when located in the engine compartment. I've got the color wiring schematic, but think a picture would be more helpful. Thanks.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    On the engine electrical console
    Senior Member 68S_SK2's Avatar
    Mar 2006
    Munich, Germany
    Hardi mount
    Hello,
    Here is a picture of the Hardi with the mount. I think the power is from the red wire?? Sorry, but I have no wiring diagramm with me at the moment.
    Best
    Claudius
    Mar 2006
    Louisville KY
    John if you need one I think I have the factoty Hardi mount.
    Tony Proasi
    52 split window coupe
    Jan 2008
    Eugene, OR
    Thanks for the photo Cladius.
    I found an original mount yesterday and droppped it off to the painter (powder) today. Once I get everything mounted I will figure out how the power is ran off of the #8 resistor (as shown in the wiring diagram). I am sure it will be apparent when I get to looking. I know there was a loose wire that might be the old power supply. That would be too easy I am sure.
    John Thompson
    Senior Member T308's Avatar
    Aug 2012
    So Cal
    Can anyone share a photo of the left side of the engine compartment showing the Fuel pump set up for a 1968 Normal? My PO thought they had a better idea and bodged it up. I'm using the parts catalog as a guide, but I'd like to see it on the car.
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
    1978 Ferrari 308 GTS
    Jan 2008
    Eugene, OR
    This is a before and after of my '68 Normal. You can see the three mounts for the fuel pump bracket. The Hardi pump had been moved to the front of the car. Yes I know the board should be black, but it looked so good all shined up I hated to cover it.
    John Thompson
    Aug 2012
    So Cal
    Thank you sir.
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
    Jan 2008
    Eugene, OR
    T308,
    Did you see both pictures? For some reason the second image isn't showing up on my computer, but shows up when I view it on my phone.
    John Thompson
    Aug 2012
    So Cal
    Yes Sir, I can see both.
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
  1. 1971 - location of fuel pump/build date question
    By Sean F in forum General Info
    Last Post: 10-17-2013, 07:48 AM
  2. correct fuel pump for 1968 911s
    By mo baig in forum Technical Info
    Last Post: 08-07-2012, 03:55 PM
  3. Fuel pump support 1968
    By egbert in forum For Sale: 911 Parts
    Last Post: 10-04-2011, 09:58 PM
  4. Fuel pump location?
    By SteveD in forum General Info
    Last Post: 07-25-2009, 09:43 AM
  5. 67 washer pump location
    By tomkirkcis in forum General Info
    Last Post: 02-02-2009, 03:53 PM
