Thread: 901/12 trans ID
    901/12 trans ID
    wanted to know about this 901/12 trans serial 709????
    anyone has info on these?
    appreciate it
    Rich
    Richard aka le Zookeeper
    early reg #1128
    Goldmember ttweed's Avatar
    La Jolla, CA
    It's listed on this page of the spec book.
    HTH,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    How are these gears and why was it optional on E and S models, was it because its a 4 speed and 5 speed were standard while 4 spd was optional?
    trying to understand the options philosophy,
    I always assumed that if its optional or extra, that it would be an upgrade, adding a desired feature?? is this the case...or is it an option todowngrade?
    aside from preference?
    is this gear combo desirable?
    "I dont know squat 'bout transmissions" ........yet!
    early reg #1128
    La Jolla, CA
    Quote Originally Posted by EARLY911ZOO
    For me, an optional 4-speed when 5-speed was standard would definitely be a "downgrade." I doubt there were many installed in the 911S or E in '68.
    The gear ratios for the 4-speed are simply spread out more in 2nd and 3rd to cover the same speed range as the 901/02. You can see they both start with A and end with Z, but the 3 gears between of the 5-speed as opposed to only 2 with the 4-speed would do a much better job of keeping the engine in the high-torque band of the motor, at the expense of shifting a bit more. Totally worth it, in my view.
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    I would second Tom...that spread from HB to S would drop your revs WAY too far in an S...or an E.
    Michael
    72 911S Coupe, Sepia Brown
  1. 901 trans
    By super9064 in forum Technical Info
    Last Post: 08-04-2010, 07:03 AM
  2. 2 915 trans 1 LSD
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 03-29-2010, 07:34 AM
  3. FS Trans Am
    By byron in forum Off Topic
    Last Post: 12-06-2008, 08:14 AM
  4. WTB: Mag 901 trans.
    By Flat Six, inc. in forum For Sale: 911 Parts
    Last Post: 10-02-2008, 11:11 AM
  5. WTB: 930 Trans...
    By Chuck Miller in forum For Sale: 911 Parts
    Last Post: 01-27-2007, 04:04 PM
