Thread: 68 oil tank options
    Sep 2006
    Maryland
    68 oil tank options
    I need to replace the oil tank in my 68 SWB, What years will fit? should I find another 68 tank? I will be building the original 2.0 engine as a 2.7, will it require a larger oil capacity? Thanks for your input
    Rob Abbott
    A 2.7 will require external oil cooling. If you go with the larger capacity tank you will have to cut the engine wall to fit the tank. Otherwise retain the 68 tank and find the fittings (couplers/reducers) so that you can run the external lines.
    I have a 2.7 in my 68.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Sep 2006
    Maryland
    Thanks Bob
    Rob Abbott
  1. Options for larger fuel tank in a '73?
    By Jim Williams in forum Technical Info
    Last Post: 04-05-2016, 03:28 PM
  2. WTB: Plastic Windshield washer tank as a catch can/tank
    By Bavaria911 in forum For Sale: 911 Parts
    Last Post: 05-29-2013, 06:42 AM
  3. '72 Oil Tank Options
    By MoparBoy72 in forum Technical Info
    Last Post: 01-16-2011, 09:23 PM
  4. Replies: 1
    Last Post: 04-22-2010, 07:24 AM
  5. Plastic tank to trade for 100 liter steel tank
    Last Post: 04-12-2010, 09:13 AM
