Thread: CV joint boot ???
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    CV joint boot ???
    Hello all
    About 4 months ago, while poking around under my car, I noticed one of my cv joints throwing grease, ok time for new boots. I order up some from pelican and go to install them. Well the boots I pulled off were 1 piece, meaning the boot and the large end metal piece, were one piece. The part I received from Pelican was a simple boot. Ok I'll pull the old boot out of the metal piece and re-use the metal piece (the new boot large end barely fit on the metal piece). Re-assemble and re-pack. Well Sat. I was under the car to adjust the clutch, and guess what....still throwing grease...no cuts in the boot, so I can only assume my makeshift boot retrofit was in-effective.
    So question...Are the CV joint boots with the intregual metal piece (large end)
    available anywhere?
    Thanks in advance
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    Sep 2006
    South San Francisco
    did someone use a vw part???
    Ok, here's a pic of what I originally removed, is it possible someone used a vw part? does it fit? At 10 bucks I may give it a shot...
    911S registry #1103
    R-Gruppe #513
    Period Dune Buggy
    Mar 2006
    Louisville KY
    Dave on the 65 I had I used super beetle CV boots worked like a charm.
    Tony Proasi
    52 split window coupe
  1. CV joint recommendation for 67 911
    By 1QuickS in forum Technical Info
    Last Post: 03-23-2014, 06:23 PM
  2. SWB CV joint
    By Christophe Penard in forum Technical Info
    Last Post: 10-07-2013, 06:02 AM
  3. CV joint(s) questions
    By Haasman in forum Technical Info
    Last Post: 04-12-2013, 07:09 PM
  4. WTB - CV Joint Boot Flanges
    Last Post: 05-18-2011, 04:48 AM
  5. Why different CV joint sizes?
    By caproader in forum Technical Info
    Last Post: 08-20-2006, 03:43 PM
