Results 1 to 9 of 9
Thread: SWB Rear Rotors - 944 vs. Stock
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Hi Gang,
    Some have been interested in the 944 rear rotor process. These are $149.00 each or you can have your local machine shop perform these mods for you.
    The "red" circles are the new mounting holes. The 911 mounting holes are slightly further out than the 944 holes. We like to reindex the entire set of holes vs. milling over the top of the 944 holes. The "blue" circles are the 944 mounts. One of them is drilled out to make the new hand-brake star access hole:
    Here's a look at the backside of the older 911 rotor. This one has developed cracks in the handbrake drum:
    Here's the backside of the 944 rotor:
    Only a very slight amount needs to be milled off the edge to make the outer diameter the same. On the last examples we received it actually made me wonder if it was needed. It seemed to be under 1mm. Here's a pair of the finished products:
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Link saved to "technical reference" folder. Thanks Eric!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Sep 2006
    Maryland
    Is it really worth the trouble to drill and chamfer the disk, the wheel and lugs hold it in place. My understanding is that they are only there to keep it from falling on your foot while changing a tire. Am I missing something? I plan on doing this on my 68. The outer diameter needs to be reduced, as well, correct? Or is it just the inner portion that is used as the parking brake drum?
    Rob Abbott
    Dec 2002
    Sandy, Utah
    They really aren't "all that" necessary. They are to hold the disc in place while setting the rear handbrake. You can accomplish the same with a couple open lugs.
    Yes, as mentioned, the outer diameter needs to be slightly reduced. I'd almost like to bolt a set up and see how close it comes. It seemed to be under 1mm. Nothing on the inside.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Mar 2006
    Louisville KY
    Eric does material have to be machined off the e-brake drum or the rotor face itself?
    Tony Proasi
    52 split window coupe
    Dec 2002
    Sandy, Utah
    Quote Originally Posted by 911quest
    Nada... pretty straight forward that way.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Outside dimension
    Tony, that 944 rotor edge diameter is larger and looks like it will touch/hang up on the caliper when everything is bolted in place. If you turn the rotor to 285mm diameter the clearance will match the 1967 part. We used a brake drum lathe (with the cutting head facing in rather than out) to trim that outside edge. It left just enough of the wear indicators for them to be useful.
    Eric, thanks for making these available. It sure is nice to have a alternate to the factory big buck item.
    Bob
    Early S Reg #370
    Dec 2002
    Sandy, Utah
    My pleasure Bob... I like researching stuff like this.
    The 944 rotor I got could have passsed for 285mm (almost). I'm sure someone has the details but, it was less than 1mm that needed to be shaved.
    Has anyone tried it w/o shaving the edge? We shave them to 285mm but, it's hard to believe the caliper has that little clearance. I guess I was surprised at how little needed to be taken off the edge.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
    Unshaved
    I put my replacement 944 rotors on the S without the shave to the outer diameter. Works fine.. Certainly cheaper than the oem part number.
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
  1. SWB Rear Rotors
    Last Post: 10-23-2008, 04:37 AM
  2. Rear Vented Rotors
    By pacarguy in forum Technical Info
    Last Post: 06-30-2008, 03:12 PM
  3. 67S rear brake rotors
    By Rick Cabell in forum Technical Info
    Last Post: 01-03-2006, 09:19 AM
  4. 67S rear rotors
    Last Post: 02-19-2004, 06:09 AM
  5. Rear brake rotors for '67S
    By Bram in forum Technical Info
    Last Post: 09-02-2003, 06:38 AM
