Thread: How to loosen the water pump strap
    I would like to remove my water pump but to save the OEM straps. How do you loosen those? Just turning CCW w/ a pin?
    Richard
    Mar 2006
    Louisville KY
    Richard just loosen them like a normal bolt just like an old swing axle 356 or VW
    Tony Proasi
    52 split window coupe
    Richard,
    Don't have your answer because mine was floating around the trunk when I bought the car so I ripped it out. However I have since purchased a new pump, hoses, connections and cleaned up my bottle. So when you get the pump off can you snap a pic for me? I am assuming there will be some sort of raised brackets to allow the 3 nipple bushings to be inserted. TX!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Bob,
    I followed Tony's advise and simply unwound it (if I recall correct, clockwise; opposite of a regular bolt).
    What exactly do you want to see pictures off? The pump was only attached w/ the 2 straps.
    Richard
    My original crusty pump had 3 rubber nipple type bushings. The new pump did not come with these bushings so I was going to rob them from my old one. They slot into the base of the pump and assumed they get inserted into the pan.
    BTW - these nipple inserts are $9 ea...who would've thunk.
    _B
    www.werkcrew.com
    Bob I will shoot some pictures and report back.
    Richard
  1. Where's this water from?
    By joetiii in forum General Info
    Last Post: 09-13-2015, 02:47 PM
  2. WTB - Expansion Tank Strap and Charcoal Canister Strap
    By sam71TargaS in forum For Sale: 911 Parts
    Last Post: 08-18-2012, 07:37 AM
  3. best way to remove (water pump) sealant?
    By preS in forum Technical Info
    Last Post: 10-28-2010, 02:08 PM
  4. Luggage Strap Retaining Bars aka Strap Clamp
    By RW7810 in forum For Sale: 911 Parts
    Last Post: 07-27-2009, 06:12 AM
  5. How do you "loosen" seatbelts
    By larry47us in forum Technical Info
    Last Post: 04-08-2005, 12:05 PM
