Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: fender to cowl seal. Where to get the NONE rubber seal?
    I believe that these days the fender to cowl seal (901.503.394/395.22) is made off rubber. On my 66 however it seems to be something like canvas.
    Since it's the seems that this was first time that the fender went of my car I tend to believe that this seal is correct. Can some one confirm? Does any one have a supplier for these seals? If not what I am supposed to get to replica it?
    Thanks.
    Richard
    Sep 2006
    La Quinta
    That is correct. I don't think you can buy them. Can you make a pattern? I'm looking for the material to make them.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Sign me up for a set.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    seal
    You may be correct and it may be origional. However I owned those cars when they were new, and I dissambled several wrecks in 1968, 1969 and I was sure they are the plastic type stuff, flat and then they spread at the top to cover the fender and the cowl?
    In later 66, they changed from the fabric type, to the black vinyl.
    Rick,
    You are correct. Mine left side is in a beater condition and is made of vinyl. My car was manufactured in May of 66.
    When did they change to the rubber seals?
    Richard
    Not sure, but there was a 65/66 thread going about other split year changes, but I don't think it touched on the cowl seals.
    You guys are a better judge of this than me, but are these seals visible? If not, why use a water absorbent material even though it's a factory-equivalent part? Seems like the fender-to-cowl area is an ideal location to grow rust. Why not use something more water tight/resistant/proof?
    Sherwood
    Quote Originally Posted by 911pcars
    Sherwood
    I was kind of wondering the same thing.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    seal
    Sherwood
    They are the black strips up by the windschield on each side of the car. Haven't you ever seen a 911? Every car from 1964 has had two, or were you funnen us?
  1. FS: One Air Horn for SOLEX 911 and rubber seal for air box
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 03-17-2014, 02:08 PM
  2. `Fog lid` rubber seal.
    By paul martin 911 in forum Technical Info
    Last Post: 04-03-2012, 07:29 PM
  3. Deck lid rubber seal
    By Cliff in forum General Info
    Last Post: 06-23-2011, 06:28 AM
  4. Rubber seal
    By chicagobreezz in forum Technical Info
    Last Post: 07-15-2009, 05:50 PM
  5. Rubber seal for SWB fresh air intake
    By john_cramer in forum Technical Info
    Last Post: 06-20-2005, 09:37 AM
