Thread: Weber IDS part needed
    Can anyone help with the part I am looking for from this thread:
    http://www.early911sregistry.org/for...ad.php?t=20042
    or any advice where I get it? Thanks
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    I have a replacement bottom that doesn't fit my factory '69 air housing.
    How can I identify the one you're looking for?
    Sherwood
    Hi Sherwood,
    the front and rear clamp is located a bit off center to the inside. This is the right side with the proper intake:
    Maybe we can swap.
    Michael,
    I'll take a look tonight and report tomorrow.
    Sherwood
    Michael,
    Here's what I have. The top one fits my '69 air filter housing. The bottom one is from a XX 911. and it doesn't fit the '69 housing.
    One end clip is centered on the end, the other end clip is offset to one side. The tension clips are also of a different wire shape and size.
    It looks different from yours.
    Hope this helps,
    Sherwood
  1. Radio part needed question?
    By merbesfield in forum Technical Info
    Last Post: 02-21-2011, 07:01 PM
  2. Electrical Part # help needed - application?
    By Cornpanzer in forum Technical Info
    Last Post: 08-24-2008, 03:32 PM
  3. Weber 46 info needed
    By BURN-BROS in forum Technical Info
    Last Post: 06-11-2008, 06:10 PM
  4. Weber 40IDTP13C Gaskets needed.
    By robboats in forum For Sale: 911 Parts
    Last Post: 06-05-2007, 12:24 PM
  5. Seat Belt Part Needed
    By 2POINT7 in forum For Sale: 911 Parts
    Last Post: 09-09-2005, 11:41 PM
