Well-seated:
I now have had at least two early 911s where the Allen head bolts that hold the rails to the seats have some loose, dropping down and jambing the seat, limiting its movement back and forth. What is a real drag is that when this occurs you can not remove the seat because the bolts to remove it from the chassis a now blocked by lack of seat travel. The first time I was able, I don't remember how, to get at the one or two bolts that had come loose with needle nose pliers and get them back in and out of the way to remove seat and locktight all screws.
Does anyone have an easy, proven way to do this? Thanks
-Allen-
PS I seem to have a lot of stuck things lately
