Results 1 to 10 of 13
Thread: LM-1 now $299; a necessary tool?
    My brother in-law informed me that the LM-1 can now be had for $299. I suspect he's hoping i'll buy it (damn VW people always on the mooch ) but i have been giving it some thought because i can't imagine being satisfied with my carbs and NOT knowing what my a/f #'s are. Not that i know wtf to do with this thing but it looks like a fun thing to learn.
    But is it necessary? If i drop $299 on this thing will i sleep better at night knowing my carbs are dead nuts perfect?
    Thanks in advance-
    Erik
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Sep 2006
    Eagle, Idaho
    A firend of mine has an LM-1 and swears by it to keep his 2.2 '70 911T sharp. I think it's best to establish a baseline on a dyno first and then use aids like the LM-1 to maintain the state of tune.
    John G.
    The reason for owning an LM1
    Ever wanted to tune your MFI pump? I mean really tune it? Like to the tune of making a '72T pump get perfect AFRs on a Mod-S cammed 3 liter? Read on:
    http://forums.pelicanparts.com/showthread.php?t=386414
    The LM1 was the catalyst to making this a reasonable proposition at home.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Oct 2004
    SW Suburbs of Chicago
    Isn't it necessary to also get the RPM capability of the LM-2 in order to accurately adjust the A/F across the full range?
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    I'd PM Jeff Higgins to be sure.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Goldmember ttweed's Avatar
    La Jolla, CA
    Quote Originally Posted by EsGeht
    AFAIK, the LM-2 has been delayed in production, and is not yet available. For logging RPM, you just need to add accessories to the LM-1: an inductive clamp pickup for the plug wire and an LMA-2 converter, which adds $130 or so to the price. If you can wait for the LM-2, it might be worth it, since it will have dual channel capacity, from what I've heard, but will be in the $700 range for that capability. It would be really nice for the 911 flat six, though, as you could log and compare both banks of cylinders at once.
    From my experience, it is necessary to have these accessories if you don't have someone else to ride along with you and watch the display on the LM-1 while you're doing on-the-road tuning. I did it alone somewhat satisfactorily when tuning an EFI system by hanging the LM-1 on the dash and stealing glances at it, but it's better if you're logging the data and can review it at your computer later with the Logworks software. Adding a TPS or MAP load-sensing trace as well as RPM to the data would be even more helpful. Without these elements, you are left with only A/F over time displayed, and it is difficult to remember what you were doing when, exactly, to interpret the data.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Has anyone used a Gunsen Colortune? Not an LM-1, but appears that it does allow you to view the combustion flame of each cylinder individually. I've heard that motorcycle tuners (multi-carb/ITB) tuners swear by (not at) them.
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    Color-tune
    I think you need to see the sparkplug to use one of these (they have a clear
    insulator).....kinda tough on a 911...
    Cheers
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    Comes with a periscope/mirror dealy to see into the cavity. Paul Abbott, who rebuilds Webers (did a great job on mine) mentioned using one of these to adjust/tune Webers. I'm going to try it. I've used a sniffer in the tailpipe and a Lamda sensor/Megasquirt method, but they all give you the average A/F ratio. This method may allow you to observe the individual cylinder A/F ratio (or approved equivalent) at any RPM. Not under load, but....might be a good DIY method until you get the garage dyno installed.
    Al Kosmal
    the X-faktory
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Tom, the LM-1 does have a logging function. The RPM converter is a must, otherwise you would just make idle and part-load adustments (hey, that's what the factory did in CMA!) and the rest of the curve would fall where it might.
    Adjusting the interal screws is a major leap forward, but not possible without the RPM converter so you can see where the dropouts in the fuel curve are.
  1. FS: Late 'JUSIN' Tool Bag for TOOL KIT
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 12-21-2013, 01:34 PM
  2. Replies: 3
    Last Post: 10-17-2013, 12:11 PM
  3. FS: KLEIN 21 Spark Plug Tool w/ Allen Key LWB Tool Kit
    Last Post: 09-27-2013, 04:18 PM
  4. WTB: Sunroof tool for a '69 Tool Kit
    By s2guy in forum For Sale: 911 Parts
    Last Post: 01-07-2009, 07:49 AM
  5. Cool tool... mapping tool that is.
    By Jens in forum General Info
    Last Post: 06-11-2007, 02:46 PM
