Fresh 200 mi. 2.7 hot rod motor, std/std crank balanced,w/rods, euro p&c's
9.8:1, new valves, "S" cams, case savers, dilivar studs, carrera tensioners, turbo valve covers, rebuilt & remachined weber 40 ida's, bored, new b'flys. new shafts, sealed and bearings(not bushed), all carb work done by h. bieker!
older bursch exh. if you want...$8000.
just chassis dyno'd @175 rear wheel hp! 170fp torque @6000 rpm!!
call or pm or email........david 310-890-5390
autosmith9@aol.com see pic on PP
