Results 1 to 7 of 7
Thread: How To: MFI Electric fuel pump overhaul
    This was too good to not share, now that I was able to find it again. From a 2003 Pelican posting:
    Quote Originally Posted by lcjjbeav View Post
    The electric fuel pump on my 1970e was inop after sitting for 10 years. Based on the junk in the tank, I figured the pump was beyond repair. So the fun part comes, I get to take it apart to see how it runs, certainly can’t hurt it. Bottom line, after taking it apart replacing three orings, acquired from the local hardware store, and de-gunking, it now is humming and pumping the correct amount with no leaks.
    Toughest part of the disassembly was undoing the “stakes” and prying the outer body from the top section. Haynes says these are not repairable, we’ll see. If any else attempts an overhaul consider it a last resort and be prepared to buy a replacement. Here are some pictures of the disassembled cleaned up unit
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    A good comment from our recently departed friend:
    Quote Originally Posted by Early_S_Man View Post
    Good show!
    I would recommend using O-rings from an industrial bearing and seal supply house, rather than a hardware store ... less likely to have been sitting on the shelf 10 years, and the material is likely to be of higher quality! Viton would be the elastomer material of choice for fuel-handling O-rings.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Mar 2006
    Louisville KY
    One note on reassembling these pumps if you overtighten the four screws the pump won't spin.
    Tony Proasi
    52 split window coupe
    Quote Originally Posted by 911quest
    Do you have a torque spec?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Subscribed
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    I've done this process before on old pumps, only to have the bearing seize after a few hours of running.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Seems like a you can't lose trying, at least...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Is the fuel pump overhaul for 911 of 1973 possible?
    By naba901R in forum Technical Info
    Last Post: 12-27-2013, 10:40 PM
  2. FS: Used MFI Fuel Pump - Electric
    Last Post: 09-04-2013, 09:34 AM
  3. FS - Bosch electric fuel pump for MFI
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 09-27-2012, 06:49 PM
  4. electric Fuel pump for MFi mounted
    By MY911S in forum Technical Info
    Last Post: 09-20-2010, 10:46 AM
  5. FS: MFI Fuel Filter Console and Electric Fuel Pump
    Last Post: 07-28-2008, 07:10 AM
