Results 1 to 10 of 12
Thread: '70 and '71 911 differences
    Nov 2003
    Sydney
    My ace mechanic has asked a curly question re door handles on the 2.2 911s.
    I need to consult a post from several years ago that stated the differences between the '70 and '71 911s.
    I can't remember if it was on this board or Pelican but the differences were quite numerous although most were very small.
    Can anyone help with locating this thread or part thread ??
    TIA,
    Dennis.
    S Registry member 536
    Hi Dennis,
    I hope you are well?
    Just a few changes include..
    The changes from deep 6 to flat 6 fuchs.
    Engine cases in 71 have piston squirters
    The trigger on the door handle changed
    In 71 I have seen some Ss with a plastic engine vent box
    I am working of a couple of 2.2S at the moment if you need me to check anything.
    Alan
    Nov 2003
    Sydney
    Thanks Alan,
    The list I am thinking of maybe came from a dealers annual technical update of some sort.
    It listed about 20 items including the differences in the number of diodes in the tachometer - yes it was THAT detailed !
    The question my mechanic asked was an observation from working on several 2.2 S models recently.
    He said that the other 911s had a door key that was inserted horizontal to the ground but mine was vertical to the ground.
    Can you check your 2.2s and let me know pls.
    Otherwise,maybe either or both my mechanic/myself should get a life sometime !!
    I will be in the UK about this time next year and look forward to meeting you and some of the DDK gang - IF I have any $$$ left after Essen !!
    Cheers,
    Dennis.
    Mid 71 fuel pump was moved from the front to the rear of the car.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    Also new for 1971 were:
    3 speed windshield wipers with intermittent feature
    US models had evaporative fuel control system
    From the Red Book
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    Luft gekuhlt Bummler's Avatar
    May 2005
    The Valley...
    Quote Originally Posted by Alan.uk
    Are you referring to the trigger mechanism itself or Porsche's change from a push button to a trigger release? '69 was the the last iteration of the push button door opener they went to a trigger style in 70 to satisfy the DOT side impact regs preventing the door from being opened upon impact.
    Stefan Josef Koch
    RGruppe #194/SRegistry #1063
    2015 Porsche Cayman S
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    Quote Originally Posted by silverc4s
    From the Red Book
    According to my 71' owners manual and my car, 71' has 3 speed wipers without intermittent feature.
    I think it is one year only then back to 2 speed with.
    Also glove box pull handle deleted and knob moved to center of door on 71'
    alan,
    My 71E door key is vertical.
    regards,
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    Hi,
    RE door handles. The triggers are exactly the same 70> but there are slight differences in the way they mount to the handle.
    I believe this to now be approx during the 70 to 71 model year change
    I have also seen the key hole in a horizontal position but only in the 72 onwards style of handle. I have several sets here but can't remember what cars they were from.
    Please see pic for the minor differences.
    PS. I have 2 x 2.2S in the workshop and both have intermittent wipers and then 2 wiper speeds
    HTH
    Alan
    Jul 2006
    Switzerland
    -glove box knob in center.
    -door lock vertical
    -fuel pump at rear
    -wipers: 2 speed with.
    71', respray but never restored.
    Registry member No.773
  1. Value differences T vs S
    By RS-GT in forum General Info
    Last Post: 06-13-2014, 09:31 AM
  2. differences between 2.7 RS MFI and 2.4 S MFI
    By pacorron in forum Technical Info
    Last Post: 11-10-2011, 11:04 AM
  3. Differences in 993 from 95-98?
    By Sacto S in forum Off Topic
    Last Post: 09-25-2008, 10:53 AM
  4. differences between swb and lwb
    By jk356 in forum General Info
    Last Post: 07-12-2007, 11:19 AM
  5. 2.4S vs. 2.2S MFI -- DIFFERENCES?
    By NeedanEarlyS in forum Technical Info
    Last Post: 12-15-2003, 03:06 AM
