Thread: Powerband of T cams
    Powerband of T cams
    Quick question - I recently bought a used 69 911 race car. Supposedly motor has stock T internals but PO said he used a 7500 RPM redline. I just drove car and it does pull hard all the way to 7500 RPM. I can't believe it still has T cams in it, any comments. I have owned several T's but have never twisted one that high.
    Phil
    Good question. My T pulls hard to the 6500 mark, and feels like it's got plenty more in it.
    I haven't had the nerve to push it any higher though.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Frank,
    Steve W replied to same question on the bird site, he does reccomend revving a T motor like that due to the cast pistons they used.
    Phil
    Thanks Phil,
    My motor was rebuilt by D. Frick at Europa Macchina a few years ago.
    He installed domed JE pistons which bumped the compresssion ratio to ???
    I think it's got more than the 6500 rpm in it, but I worry about the crank's ability to rev higher than that.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Nov 2002
    Fremont, CA
    Crank is fine to about 73-7400 in the 2.4s...same crank in the 2.4 T as the 2.4 S
    JEs are forged...good for high rpm race use
    It's not that T's don't make power at 6500+ or something--they do--however, you'd have MORE if you shifted into the next gear ..
    scott kinder
    kindersport@gmail.com
    Registry #614
  1. What cams are these?
    By Alex65 in forum Technical Info
    Last Post: 03-24-2014, 02:01 AM
  2. Cams
    By mike curnow in forum Technical Info
    Last Post: 05-30-2011, 03:04 PM
  3. Trying to ID cams.
    By rngpc in forum Technical Info
    Last Post: 06-13-2007, 07:10 PM
  4. 906 Cams
    By ErVikingo in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 05:10 AM
  5. Help ID cams 901.105.139.OR, 901.105.110 OR
    By MarkS in forum Technical Info
    Last Post: 01-19-2007, 03:33 PM
