Results 1 to 7 of 7
Thread: SWB rear trailing arm: what is the diff. between a regular and S
    As the title reads, what is the difference between a regular/ normal SWB rear trailing arm and the arm of a S? Is it the hinge bolt for the rear stabi and/or are there other differences?
    Richard
    N-s
    As far as I know, only provision for swaybar makes it different.
    Trailing arm sway bar mount stud for the "S" is the only difference.
    Bob
    Early S Reg #370
    Thank you for posting a picture.
    BTW did you paint your arms, powder coat or did you opt for another process?
    Richard
    Richard that is Krylon semi-flat black paint or PJ1 Coatings Fast Black - Satin Black 500deg.. The front suspension is powder coated.
    Bob
    Early S Reg #370
    The "hinge pin" ball is available through Porsche and when installed on a non-S trailing arm correctly will look exactly like the one in the picture above.
    -Allen-
    Dec 2006
    Las Cruces, New Mexico
    Pins are also available @ Pelican.
    Early 911S member #166
  1. Rear Trailing Arm bushings
    By luke-44 in forum Technical Info
    Last Post: 01-20-2014, 06:45 PM
  2. FS: SWB Rear Trailing Arms
    By mrbmw2002 in forum For Sale: 911 Parts
    Last Post: 07-11-2013, 12:46 PM
  3. FS: 73 Rear Trailing Arms
    Last Post: 04-18-2013, 03:24 PM
  4. FS: Rear Trailing Arm Monoballs
    By chris_seven in forum For Sale: 911 Parts
    Last Post: 12-02-2012, 11:00 AM
  5. Rear Trailing Arm Bushings - New
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 07-05-2011, 04:00 PM
