Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Weber 40IDS3C questions (and photos!)
    I just pulled the Weber 40 IDS 3C carbs from my '69S motor. They ran great, but the MFI is now one step closer to returning (and we all know MFI is runs better than carbs, right? ). I am wondering a few things about these carbs:
    The serial number on the carb: is it sequential like engine cases?
    Obviously made in Italy:
    The reason I ask is that my car had a complete '67S top end on it. SUPER early; all of the casting dates were September '66. This number is very early as well, compared to the other '67S carbs I have seen.
    Next, I have seen manifolds with round and rectangular holes in the manifold bridge (these are obviously the round ones). Any idea what the difference is?
    More gratuitous photos:
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenik,
    Those are PMO manifolds under the IDS carbs.
    The Webers are worth good money if they are in good shape with tight shafts.
    A restorer will want OEM manifolds but someone doing a conversion will not care.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    How do I tell if the shafts are tight? The sure don't wiggle in their bores, if that's it. They ran great on my 2 liter.
    Lame on the manifolds, but that's life. I'd rather have the carbs if given the choice.
    Thanks again, Steve!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member sam71TargaS's Avatar
    Aug 2006
    Colorado
    PMO Manifolds
    Kenik,
    If you want to sell the PMO manifolds I would be interested (or I could trade my stock manifolds plus a little dough)...
    Sam
    PS - I guess I am trying to buy your whole stash it seams
    Actually, not that lame on the manifolds. $400 new!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi,
    That is an interesting point RE the serial number on the carb. I have a couple of 2.0 S motors/ IDS carbs and will check the numbers in the next few days.
    Alan
    Alan,
    Could you possibly post a photo of the correct manifolds?
    Thanks.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    No problem Kenik,
    One set are on the car (68S) and the other are having all the shaft bushes re-done so I will try and get a pic ASAP.
    Alan
    Thanks so much!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi Kenik,
    I have just taken some pics for you. Today I vapour blasted one of the 67 S manifolds so it showed more of the details. They are date stamped, both have 67 on them. I will check the 68 ones I have in a few days.
    I hope this helps
    Alan
  1. FS: Weber 40ids3c, 40ids3c1 67 & 68 911s
    By targa74 in forum For Sale: 911 Parts
    Last Post: 07-04-2013, 08:58 AM
  2. Replies: 11
    Last Post: 04-11-2010, 06:19 AM
  3. Fuel system rebuild questions (early Weber)
    By ralfabco in forum Technical Info
    Last Post: 07-23-2007, 10:30 AM
  4. Weber rebuild questions
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 12:52 PM
  5. Several Weber questions
    By Markus in forum Technical Info
    Last Post: 12-20-2002, 06:13 PM
