Thread: WANTED H1 retaining screw
    I need the retaining screw for an H1 headlight.
    Does anyone have one or two or know where I can source one?
    Jule
    Jan 2006
    Naperville, IL
    Jule,
    Are you talking about the screw that attaches the light to the fender or a different screw?
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Yes, it holds the H1 light assembly. Its different from the stock light screw. It appears that there is a similar screw for painted rims on the light but I think they are threaded for a second screw to hold the painted rim.
    If I'm wrong let me know, there are plenty much more knowledgeable than I.
    thanks,
    Jule
    Jan 2006
    Naperville, IL
    If I am understanding you correctly then you are looking for the screw that is missing in the following picture
    When I removed the US sealed beams from my car the exact same screw was used to install my H-4's and also fits into the H-1's. My car is a LWB;
    Stoddard's lists this part as 911-631-146-01 and it seems in stock.
    I hope this helps; Other wise I have a parts H-1 assembly.
    Good Luck,
    -Andrew
    '72 911E
    S Reg #1074
  1. WTB: S Caliper retaining pin x 1 and retaining clips x 2
    By Andy B in forum For Sale: 911 Parts
    Last Post: 05-19-2013, 07:46 PM
  2. 67s screw or no screw - an interior question
    By joshkras in forum General Info
    Last Post: 02-10-2013, 02:53 PM
  3. WTB NOS TN2 and TN4 Fog light lenses and TN2 retaining rings
    By pkg911 in forum For Sale: 911 Parts
    Last Post: 05-13-2011, 08:23 AM
  4. Emblem retaining clips??
    By Zuffenhausen in forum Technical Info
    Last Post: 11-28-2009, 09:55 AM
  5. Missing Intake Valve Retaining nut
    By apokon in forum Technical Info
    Last Post: 04-19-2004, 05:31 AM
