Results 1 to 10 of 11
Thread: Shipping Engine
    Sep 2006
    La Quinta
    Shipping Engine
    Have any of you had to ship an engine from one coast to the other? How do you do it...and what's the best way?
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Jan 2006
    Naperville, IL
    Dear John,
    At the Hot Rod machine shop that I worked at this past summer there were two main ways;
    1) Strapped and Bolted to a Pallet then Stretch wrapped.
    2) Same as above except a plywood crate was built on top to encase the engine. (only shipped two of those $20,000+)
    The shop generally used Freight Quote.com (search?) to find the best rate; Insurance was also used through or the carrier or a thrid party depending on the situation.
    Hope that helps,
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Feb 2007
    San Diego
    This is always a fun one.
    Couple methods of shipment. Door to door, or terminal to terminal. Often when doing a door to door the trucks do not have lift gates and the shippers often require a fork lift or loading dock. Door to door can be very expensive - sometimes not, although very convenient. Just remember the lift gate problem. Terminal to terminal is very reasonable but you will have to deliver the engine or pick up the engine from the terminal - the terminals all have forklifts so loading and unloading at the terminal is no problem.
    Shipping freight has some of the widest range of price quotes. One place will quote $1200 to ship and the next will charge $300 for the same exact service so shop around. I have used ForwardAir.com and had great experiences with them but they are terminal to terminal only.
    Packaging:
    First you will need a pallet - get a good strong one. You will need to strap the engine securely to the pallet. I like using cheap ratcheting straps as you can get them very very tight. A secondary method of securing the engine to the pallet is highly recommended - use a heavy gauge wiring like re bar tie wire, wrap it many times around the exhaust & pallet.
    Then the choice is to crate or not to crate.
    I would crate anything with fuel injection or carburetion still installed. If is just a longblock with no peripherals then strapping tot he pallet works fine. To make the crate you just simply build a frame with 2x4s and add sides to it. Chipboard works well for side material as it is the cheapest sheet plywood available and plenty strong. I must emphasize use SCREWS not nails as nails do not hold the box together tight during moving.
    Keep in mind logistics - the size of your truck vs the crates size - camper shells are not forklift friendly. Lifting a 500lb Porsche 6cyl with and extra 100lbs of wood can be tough for even 4 men to lift. I have boxed up engines while they were in my truck and I have had engine sit in my truck for a week or so until they can be unloaded with friends.
    I have shipped many engines over the years - good luck
    -Mark Allen
    freightquote.com works great.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I have shipped engines to Fla and Texas for $488 and $218 respectively and it doesnt need to be fully enclosed...
    you can leave the top open or build side fences like in these pics of
    trannies I sent.
    I have engine crate pics however unable to find them
    same as these essentially...quite easy to build
    that tiptronic weighed in at 295lbs with the crate no wonder those cars need 400 horse power
    a 901 weighs approx 100lbs
    Richard aka le Zookeeper
    early reg #1128
    Sep 2006
    La Quinta
    Thanks guys for the ideas!!
    Registry #983
    R Gruppe #741
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    I had mine shipped from columbus, ohio, to Duane Spencer in Northern California so he coudl rebuild it.
    I used the shipping company he recomended -i can look it up if you need it.
    I crated the engine up when i shipped it. best way to do this is to buy a palet from a warehouse or store. then drain teh fluids from the engine, place it on top of the pallet, and then build walls around it, and a top over it, basically boxing it in on all sides. the shipping company will advise you of any special directions (ie hwo to label it or put an address on it).
    it was about 500 each way to ship my engine in 2005
    using a pallet is an excellent platform, as it is about the right size for an engine, and it also makes it easy for teh shipping company to pick it up with a forklift or a fork jack.
    Harry Hoffman
    356 Registry Member #36691
    Crate it..
    And, add blocking plates around the pallet, to keep the forks from getting pushed to high and into the engine.. Mark it so that they won't want to put anything on top of it.
    Definitely go Terminal to Terminal if you can, will save a ton of cash.
    I've shipped a few engines and some scooters, not cheap..
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    Mar 2006
    Louisville KY
    Not a lot to add but I had a Boxster motor shipped from Florida to Kentucky for 175.00 with Forward Air, they seem to be the most resonable.
    Tony Proasi
    52 split window coupe
    Oct 2005
    wash dc/ los angeles ca
    shipping engines
    I would second Tony's suggestion..I have used ForwardAir.com between
    5 and 10 times through the years.
    1. they have terminals throughout the country at most larger airports
    2. they can give you terminal to terminal svc usually within 3 days CONUS
    3. they will provide an estimate given weight and size dimensions including
    fuel surcharge
    4. If you prefer door to door they have local truckers with lift gate access
    that will charge a minumum of 75.00 on each end
    5. the only hitch can be if you haven't got an account to bill to they
    require cashiers checks or money order upon drop off for precisely the
    amount weighed.
    They are reasonably competitive given the recent spike in deisel prices
    my .o2 Bert
  1. Shipping by air.
    By Richsmith901 in forum General Info
    Last Post: 06-11-2013, 06:40 AM
  2. Replies: 5
    Last Post: 10-16-2012, 09:49 AM
  3. Shipping a transmission - how to?
    By Homemade 911 in forum General Info
    Last Post: 08-27-2007, 08:54 AM
  4. Shipping to Europe
    By A.T. in forum General Info
    Last Post: 04-17-2007, 03:43 PM
  5. Shipping Help??
    By VIper Green E in forum General Info
    Last Post: 04-03-2006, 08:44 AM
