Thread: Easy Air filter question maybe too easy
    Member A_Alfa's Avatar
    Jul 2006
    Spain / Germany
    I have changed the air filter in my 72E MFI with a BMC one (similar to K&N), no cone or umbrella nothing like that, the filter shape is the same and fits in the same air filter compartment as the standard.
    The afraid to ask question is, when I put the air filter inside the compartment, the round compartment is significantly bigger than the filter and therefore the round filter lays on the bottom of it, and in order to place back the cover of the air filter compartment and close it, the filter needs to be moved up doing a certain equilibrium, so it fits in the exact center (same distance to the borders up down right and left) of the circular air filter compartment.
    Is there a trick/special procedure to perform this equilibrium? I am use to the snugh fit flat filter in the other cars....
    I have checked that the BMC filter is correct for the 911 72 MFI model.
    Thanks. Arturo
    Early S Reg. #1263
    72´911E
    95´993
    02´986S
    Jan 2006
    Naperville, IL
    Generally,
    I find it easier to place the filter on the "end cover" first, then balance it and install it into the housing.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Jul 2006
    Spain / Germany
    Thanks Andrew, will try this way.
    Early S Reg. #1263
    72´911E
    95´993
    02´986S
  1. Jan 4 at EASY
    By Jim Breazeale in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 01-06-2014, 05:59 AM
  2. SAT Oct 6 at EASY
    Last Post: 10-04-2012, 01:35 PM
  3. easy steering wheel question
    By CarmelSkip in forum Technical Info
    Last Post: 10-05-2011, 04:36 PM
  4. An easy question re: hood latch post
    By Sandwich Boy in forum Technical Info
    Last Post: 09-12-2011, 09:22 PM
