Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: 917 - RSR Brake Calipers
    Senior Member mrg3.6's Avatar
    Nov 2007
    United Kingdom
    Does anyone know what the differences (technical or otherwise) are between:
    1) pre 73 917/RSR brake caliper and....
    2) post 74 917/RSR brake caliper.
    I am particularly interested to know whether both calipers are the same (side to side) width
    Thx
    Martin
    Calipers
    The 73 callipers are probably about the same size as the 74's but they do look different. Do a search under slide valve RSR and there are pictures of both. Armando has done a great job with this site.
    Nov 2007
    United Kingdom
    73 / 74 917 RSR Calipers - Width?
    Quote Originally Posted by varunan123
    here are the two calipers
    Appreciate the response.
    From the photographs the 74 calipers looks to be wider than the 73 calipers - any idea on the respective widths (side to side)?
    Thx
    Martin
    Some pics of 3L RSR repro calipers
    Nov 2007
    United Kingdom
    Quote Originally Posted by OliveR
    Hi Oliver,
    Same question - how wide (side to side) are these calipers and are they an accurate copy of the originals?
    Thx
    Martin
    917 Calipers for RSR
    The wide versions used on the '74 were the so-called "long range" calipers of the 917 that held a deeper pad with more friction material for endurance racing.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Nov 2007
    United Kingdom
    Quote Originally Posted by Flunder
    The wide versions used on the '74 were the so-called "endurance" racing calipers of the 917 caliper that held a deeper pad with more friction material.
    Tom,
    You don't happen to know what the 'exact dimension' is for the width of a '74 caliper do you - I am really struggling to get an answer on this one?
    Thx
    Martin
    Senior Member boba's Avatar
    Jul 2006
    DFW
    I think there were 3 disks that could have been used 28, 32, and 35. There were also different pad thikness sprint vs endurance. The combination if the pads and disk was refered to as the stack height. There were different bridge peices which could be used to build dif caliper height. If you have a set of 930 calipers you can look at them and see what I am refering to as the pads were the same F&R but the disks were 28R and 32F and so the bridge peices are two different heights. 4mm diff.
    I know this does not give you a specific answer to your question but it will help you understand why you will see variation. I will try to get you a measure off a R 73 RSR on Monday.
    Hope this helps,
    Bob
    Nov 2007
    United Kingdom
    Quote Originally Posted by boba
    I know this does not give you a specific answer to your question but it will help you understand why you will see variation. I will try to get you a measurement off a R 73 RSR on Monday. Bob
    Bob,
    Thx for your feedback - very useful.
    I have just measured my front 930 calipers and they are approx 6 1/4" wide whilst I 'understand' that the 73 RSR caliper are the same?
    Now my problem is that I need to know the dimensional impact of the 'endurance stacks' on a '74 caliper like the one below, so I can determine whether the stack offset can be physically accomodated behind standard 9" fuchs/RSR flares mounted on 73 bilstein front struts.
    Martin
    Does anyone have a weight difference between the early and late fin designs?
  1. how much for a set of 67/68 brake calipers
    By moito in forum General Info
    Last Post: 01-15-2014, 05:18 PM
  2. S brake calipers
    By merbesfield in forum For Sale: 911 Parts
    Last Post: 02-02-2011, 05:55 PM
  3. Turbo brake calipers
    By tfiv in forum For Sale: 911 Parts
    Last Post: 10-10-2010, 09:24 AM
  4. WTB - S Brake Calipers
    By FL-Frank in forum For Sale: 911 Parts
    Last Post: 03-03-2008, 05:51 AM
  5. brake calipers restoring
    By swisscheese in forum Technical Info
    Last Post: 12-14-2003, 06:16 PM
