Thread: Speedo cable
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    Speedo cable
    I have a 71E with a 901 tranni. I am now on my third speedo cable in a year.
    they keep sheering off in the rear of the cable near the transmission. couple of questions.
    Is that what I should expect, and just plan to keep replacing them. ( I Have gooten good at it)
    Is there a way I can repair the cable withough having to pull the old one out. ie replace the inner cable. I looked on the web, and they used to make a slide in repair, but it is NLA.
    Any advice will be greatly appreciated.
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    Dec 2007
    Spartanburg SC
    Hmm
    No alternative solution.
    I talked with an electrical engineer friend of mine yesterday. I am thinking of making a remote sensor on the transmission with a moter to drive the spedo. will have to see if we can make it work.
    BTW no kinks in the cable... They are just failing on me.
    Mar 2006
    Louisville KY
    Where is it breaking? Is the grooved section breaking off the cable near the speedo drive or is it further up?
    Tony Proasi
    52 split window coupe
    When you replaced the speedo cable the first time did it get routed the same as the orignal. Is there a sharp bend anywhere. I was amazed the way the cable was routed in the trunk behind the dash. I always use extra quality cable on the new cable. Lube is your friend, always . Just a thought.
    Regards, Bill
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
  1. FS: Speedo Cable - BRAND NEW
    Last Post: 06-17-2011, 10:48 PM
  2. Speedo cable connection to Transaxle
    By gcdpetaluma in forum Technical Info
    Last Post: 06-25-2009, 07:14 PM
  3. Can one Buy a Speedo Cable Elbow Bend?
    Last Post: 02-01-2006, 08:51 PM
  4. speedo/ odo cable removal
    By fuegos100 in forum Technical Info
    Last Post: 06-01-2004, 06:50 PM
  5. Need to be talked through replacing a speedo cable please!
    By wolfturbo in forum Technical Info
    Last Post: 05-08-2004, 08:30 PM
