Thread: Case Transition 4R/5R to 7R
    While working on my car (seems to take forever!), my mechanic is also starting on another car which will require a replacement case and needs some advice on which version would be appropriate. He asked me if I could pass this question on to the experts at the S Registry:
    Does anyone know when exactly the engine case transitions took place between the following versions
    - 4R/5R without reinforced "ribs"
    - 4R/5R with reinforced "ribs"
    - 7R with 92 mm cylinder base
    - 7R with 97 mm cylinder base
    My car (chassis 9112300871, engine 6321334) has a 4R/5R case, but I understand the 7R started coming in around 1973. Any idea on dates / chassis numbers where the changes took place?
    Thanks for your help!
    Best regards, Guru
    Guru Sivaraman
    1972 S
    1977 3.0 Carrera
    Early S Reg. #1199
    Search this forum:
    7R Mag cases after mid-March '73, but some mix'd in allready from Des72/Jan73. read these treads:
    http://www.early911sregistry.org/for...hlight=4R%2F5R
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    John,
    Thanks for the help! I did search but missed that useful second thread. "7R" is not allowed as a search term
    Does anyone know about the reinforced and non-reinforced 4R/5R cases or about the two types of 7R cylinder base my mechanic referred to?
    Guru
    Guru Sivaraman
    1972 S
    1977 3.0 Carrera
    Early S Reg. #1199
    Bruce's book has useful information somewhere in the engine evolution section about the two 7R cases.
  1. Final thread on transition from 65-66 model yr!
    Last Post: 04-21-2022, 03:03 PM
  2. 65/66 final transition #2
    Last Post: 01-22-2022, 11:50 AM
  3. 1966 to 1967 transition
    By davep in forum General Info
    Last Post: 06-19-2010, 05:26 PM
  4. Replies: 5
    Last Post: 03-03-2008, 07:11 AM
  5. 4R/5R to 7R transition
    Last Post: 06-11-2007, 05:43 PM
