Thread: WTB: 65-67 brake fluid reservior
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    Anybody know where I can get a single circuit brake fluid reservior? While I was removing the line to the master cylinder, the nipple on the bottom of the old reservior twisted off...crap.
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    If no one on this list can help, give EASY (Emmeryville) a call.
    Richard
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    check with www.912bbs.org
    several people there are doing a swap to a dual master (especially Robert ANderson in Texas). you might check with them to see if you can get his single reservior when they are done next week. http://912bbs.org/index.php?a=thread&p=185520
    if all else fails, classic and speed parts might be able to get a new one for you (call teh number on their site and check -only a small fraction of their parts are on their site), and if that doesnt work, EASY is an option, or you can convert to a dual circut, using Classic and Speed Parts dual circut conversion kit. http://classicandspeedparts.com/prod...a1145594ca2d1c
    Harry Hoffman
    356 Registry Member #36691
    Rich...Stoddards has them...same as the 356 part
    Jun 2007
    Lake Stevens, WA
    Johnhora, just ordered one from Stoddard. Thanks!
    Rich
    1966 911 #303872
    ES#1197
    RG#478
    You're very welcome Rich...
    I found it easier to install the hose on the reservoir first and then feed the hose down and push it on to the MC...the damn little nipple on the bottom is easy to twist off....lube it and the inside of the hose with a little brake fluid first...makes it go on easier....just try not to do much twisting...
    Good luck!!
  1. RSR Brake fluid reservoirs?
    By Mike_Moore in forum General Info
    Last Post: 07-01-2015, 05:42 PM
  2. Which Brake Fluid to use ?
    By shipard in forum Technical Info
    Last Post: 01-17-2013, 10:40 AM
  3. WTB brake fluid reservoir for 73 RSR
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 04-17-2012, 01:03 AM
  4. FS: Brake Fluid Reservoir
    Last Post: 08-03-2008, 05:54 PM
  5. WTB: 65-67' Brake Fluid Reservoir
    By jhora in forum For Sale: 911 Parts
    Last Post: 10-20-2006, 12:13 PM
