Results 1 to 2 of 2
Thread: Weber jetting on a 2.2 E
    Bummer that the PO removed the mFI in favor of webers................here is the current set up:
    30 venturis
    180 air corrections
    125 mains
    f26 tubes
    taller 2ndary venturis
    55 idles
    Am interested in feedback regarding bumping the venturis to 32mm and the mains to 135? Street car with sport muffler.
    Thanks.
    I can only give you my experiences with 30 venturis and 125 mains on my old 2 liter T engine; otherwise stock. No problem.
    I don't see any issues with 32mm venturis and 125-130 mains on a 2.2, but those with more direct experience may add more info. I think your idle jets could be leaner. A search in the archives here or on PParts should provide more data points.
    MHO,
    Sherwood
  1. Correct Weber jetting for a 2.9?
    By s2guy in forum Technical Info
    Last Post: 01-21-2010, 08:48 AM
  2. Nedd Help With Weber Jetting
    By gruen911 in forum Technical Info
    Last Post: 09-23-2009, 04:59 AM
  3. Weber Jetting
    By pacarguy in forum Technical Info
    Last Post: 06-28-2008, 10:27 AM
  4. Weber 40 IDA jetting
    By zaza in forum Technical Info
    Last Post: 03-08-2005, 09:51 AM
  5. weber IDS carbs - jetting
    By swb911s in forum Technical Info
    Last Post: 04-03-2003, 04:26 PM
