Results 1 to 9 of 9
Thread: Undercoating?
    Undercoating?
    Hey guys, I'm still working on my project but it comes to the idea of engine bay and trunk (question thanks to Bob Tilton's post) would you paint it black as it should be with undercoating or without... Or paint it body coloured with or without undercoating?
    I'm leaving the car right now AS IS but maybe I'll try some Lightweight things that can be removable..
    P.S. the car is a really early 1970
    What would you do? I'm seeking perfection
    Thanks everyone,
    Human.. All too human
    Dec 2004
    Engine compartment?
    If I'm reading your post correctly, you're thinking about using undercoat in the engine compartment. This, to the best of my knowledge, would not be appropriate. The engine compartment is smooth from the tins on up. Below the rubber seal at the edge of the tins, you can apply undercoat to the exposed chasis.
    Anyone else?
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    The correct way to do the 1970 trunk is, primer, undercoating, extrernal paint and lastly brushed on satin black. The undercoating is far up the sides of the engine bay. I will post a picture of the original undercoating of my 1971 911S. You can see that a lot of washing has removed some of the satin black and exposed the external color on top of the undercoating. You can also see that the undercoating has been sprayed on thick all the way up to the edge of the engine lid opening. The yellow crap on the wall between the engine room and the backseat is just glue that attached the sound deadening mat.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Dec 2004
    Zith's pictures are 1005 correct. My mistake!
    It has been so long since I stripped mine out I had forgetten what I removed. I should know better than to trust muy memory. As they say, it is the second thing to go.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Zithlord is right about the engine compartment. THe front trunk was primer with some body color accidentally sprayed for effect. It looks like crap, but it is correct. Probably won't will you any concourse points though.
    In the picture below the car was originally Sepia Brown. We didn't paint the trunk because of time constraints (for a race). You really can't see it too well in the picture but the brown on the inner fenders is thin and feather/tapers off till there in virtually no brown paint at the center. This trunk is clean; it really looks this crappy.
    The front trunk also have undercoating. Liberaly in the lower parts and thinner towards the top of the sides and the top part behind the gas tank(towards the driver). As Brick says, the bodycolor is sprayed on top of the undercoating but thin/dusty towards the top of the sides and around the smugler box/air ventilation system. All the yellow area has undercoating as described above, and this is an original front trunk before I restored it(and the gas tank)
    John - great illustration and helpful to my current project! TX!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    No prob Bob!
    If anyone needs more pictures, I have loads I can send to you.
    great photos everyone..
    I had in mind to do it as this.
    No undercoating, all satin black
    What do you think it would be?
    Also the engine bay? Satin black, no undercoating
  1. Factory undercoating on a '72
    By Phil Gilsdorf in forum Technical Info
    Last Post: 01-19-2021, 10:00 AM
  2. Painting or undercoating or not?
    By Soterik in forum Technical Info
    Last Post: 04-21-2010, 04:28 PM
  3. undercoating ?
    By robmog in forum Technical Info
    Last Post: 07-20-2009, 05:15 PM
  4. No undercoating ? I need feedback...
    By RS-GT in forum General Info
    Last Post: 03-16-2009, 05:26 AM
  5. What To Use For Undercoating?
    By FHernand in forum General Info
    Last Post: 12-13-2006, 07:04 AM
