Results 1 to 2 of 2
Thread: Advice for setting timing...
    Have a rebuilt distributor in the car and need to set timing.
    Motor is 2.4 w/ 2.2S pistons and webers w/ s cams SUPPOSEDLY.
    Where should i be setting the timing as a starting point so i can get the carbs tuned?
    Erik
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    It depends on the advance settings in the distributor. For your engine, you'll want a total of not more than 30-35º advance @ 6000 rpm including the initial static timing. If your distributor is not an S distributor, it'll have more conservative advance characteristics with an assumption initial timing is retarded (ATDC) instead of advanced (BTDC).
    What distributor do you have, and if rebuilt/recurved, what are the specs?
    Sherwood
  1. Setting up Konis
    By Fishcop in forum Technical Info
    Last Post: 07-17-2015, 12:01 PM
  2. gap/dwell setting question
    By robmog in forum Technical Info
    Last Post: 09-29-2012, 06:11 AM
  3. torque setting please
    Last Post: 07-24-2011, 09:45 PM
  4. Weber setting for a 2.2S Motor
    By 911E&26R in forum Technical Info
    Last Post: 05-05-2010, 06:46 AM
  5. Replies: 10
    Last Post: 07-14-2009, 10:52 AM
