Thread: H1 / H4 compatibility
    Can the trim ring from an H4 assembly be used to replace a damaged H1 ring?
    Senior Member boba's Avatar
    Jul 2006
    DFW
    No. One of the main reasons is that the H4 has 2 adjustment screws and the H1 has 4 adjustment screws.
    I do not know if the H4 ring could be modified to work or not.
    H1/H4 Compatibility
    10-4 Boba.
    50/50
  1. Motorola/Bosch VR compatibility for 1971 911T
    By scottinbflo in forum Technical Info
    Last Post: 09-29-2011, 11:42 AM
  2. 906 cams Q - compatibility with 2.0s 67/68 carbs.
    By gilbert911 in forum Technical Info
    Last Post: 03-19-2011, 05:10 PM
  3. Oil cooler compatibility
    Last Post: 04-18-2008, 08:44 AM
  4. Bosch CDI unit part no's and compatibility
    By fourteenten in forum Technical Info
    Last Post: 08-23-2007, 02:00 PM
