Thread: Need help I.D.ing this piston
    Ok, so this is a real needle in a haystack.
    I have FIVE 89mm Mahle pistons. Initially, I thought that they were Euro RS pistons, but they are not.
    If you notice, the valve pockets seem to be deeper and the crown higher than a 2.7 RS Euro piston. I suspect that they are the Mahle 2.5 short stroke competition pistons as uses in the GTU class back in the 80's.
    Can anyone confirm this for sure and even better, does anyone have a stray piston that they would sell?
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    RS pistons are 90mm, so it is deffinitely for a 2.5. Short stroke 2.5s appeared in 71 or so? It could predate IMSA.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Ah yes, you are right. So these do me no good since I would need the 89mm cylinders too.
    10 sec 67 VW
    Jan 2006
    Naperville, IL
    Dave,
    Nice find. I would still hold on to them. you would always send one of them to Ross or JE and have them make you custom copies (Should be less then 1K?). Then get some LN engineering cylinders to go with'em.
    PM me if you want copies; my summer job does alot of business with Ross; I could poke around for ya. Might want to check on Rings too.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
  1. Need a JE piston for a 2.4
    By cmcfaul in forum For Sale: 911 Parts
    Last Post: 10-08-2010, 01:48 PM
  2. WTB - 2.4S piston
    By JPlonghood in forum For Sale: 911 Parts
    Last Post: 03-08-2010, 05:28 PM
  3. 2.0 E piston top
    By Mudi in forum Technical Info
    Last Post: 11-07-2008, 12:17 PM
  4. In need of a piston
    Last Post: 11-12-2006, 05:27 AM
  5. WTB 1 only 2.0 S piston
    By glaverbel911 in forum For Sale: 911 Parts
    Last Post: 01-29-2006, 06:15 AM
