Thread: VDO Tach: Pin1,3,4 Labeling
    Aug 2007
    The Woodlands, TX
    Can anyone tell me the wiring designation for Pin 1,3,&4 for a '73 VDO tach are? I can't seem to find a wiring diagram anywhere in past posts or on the internet.
    Option1:
    Pin1: Negative
    Pin3: Tach source
    Pin4: Positive
    Option2:
    Pin1: Tach
    Pin3: Negative
    Pin4: Positive
    Both the red and blue/yellow wires have 2 leads into a common female end for connecting with the tach. Pin3 was a single black. I made a diagram of what wire went to what plug before disassembling.
    I am trying to wire-up a tach I had refurbished and added voltmeter. Below is a pic of the backside with thick red-pos, black-neg, green-tach, thin red-highbeam.
    No highbeam going back in so that line will be dead. Get no reading from either voltmeter or tach from Options 1 or 2 from above.
    Car is a 3.2 conversion thus assumes the signal comes from Motronic versus CDI. The wiring in the diagram above worked fine on the '73 gauge before pulling it out for refurbishing. Perhaps the new guts with 4-6-8cy options can't read the motronic signal? Strange, volmeter doesn't work regardless if pin1/3 (blue/yellow-black) interchanged. Signals and bulbs work on the gauge, thus think it is a power issue with the tach internals with volmeter hardwired to them (tach doesn't work thus volmeter wouldn't work)
    Maybe related...ignition off, tach lights come on (as other gauges) when main light knob pulled. With ignition on, tach light on by default, turns off when main lights turn on (all other gauges on).
    Thoughts?
    Many thanks!
    -Mike
    EarlyS #1320
    '71 T/RS LWT 3.2L
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    Hello from Le Mans
    It is
    Pin1: Positive
    Pin3: Tach source
    Pin4: Negative
    From the obscure trivia and general comments department:
    It is my understanding that any terminal labeled 'G' on the instrument is not Ground/Grund. It is 'Gabe' from the german 'give', as in: "this is where the electrical signal from the sensor (oil level or whatever) 'gives' in to the instrument.
    Don't ask me how long it took me to figure that one out.
    73 S with sporto and 69 912 now out of rehab
    Aug 2007
    The Woodlands, TX
    Thanks guys. Figured out the 37yr old wiring Gremlins. Runs great!
    -Mike
    EarlyS #1320
    '71 T/RS LWT 3.2L
  1. 912 Tach
    By MoparBoy72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-22-2010, 04:18 AM
  2. FS-NOS tach in the box
    By route66kix in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-08-2010, 11:21 AM
  3. S tach FS
    By 66S in forum For Sale: 911 Parts
    Last Post: 03-25-2009, 03:49 AM
  4. 10 000 RPM Tach
    By 1st in forum General Info
    Last Post: 04-19-2008, 02:40 PM
  5. MSD w/ Tach Adapter - But Still no Tach reading?
    By gruen911 in forum Technical Info
    Last Post: 07-14-2005, 12:39 PM
