Thread: How does the plastic grip on the e-brake...
    ...handle come off? Is it glued? I have chips in both the handle and the button and want to replace them. It looks Like I will need to heat the handle and try to pull the grip off...or better yet, just grid it off. I haven't examined the button yet, but I presume I will have to disassemble the lever arm to get it out? Thoughts?
    Speedo
    Heat and force should do it. The one that I got from Porsche a few years ago didn't match the original - it had a pebbly surface whereas the original is smooth.
    Tom F.
    Long Beach, CA
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    The handle is held on by a brownish glue. Looks almost like a contact cement. I've used heat. The button simply screws onto the rod that it uses to actuate the gear teeth. So... screw the button off and carefully heat the arm until the handle comes loose.
    If you're going to all this trouble you may want to heed Tom's advice. The new ones don't match. You may want to find a good used handle. I just sold one on evilBay for around $50.00 that would have fit the bill.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Take a razor blade, cut thru the plastic lengthwise, and peel it off. It's easy.
  1. Hand brake lever plastic handle removal ?
    By mac73s in forum Technical Info
    Last Post: 12-14-2013, 01:22 PM
  2. WTB 380mm thick grip rs/rsr wheel and hub
    By advtracing in forum For Sale: 911 Parts
    Last Post: 09-10-2012, 01:05 AM
  3. Replies: 3
    Last Post: 04-22-2012, 06:07 PM
  4. FS: RS - RSR 380MM Thick Grip Steering Wheel
    By Ramon Gellida in forum For Sale: 911 Parts
    Last Post: 05-10-2011, 01:15 PM
  5. Replies: 2
    Last Post: 07-18-2008, 06:11 AM
