Results 1 to 7 of 7
Thread: 67 911S Wiring Question
    I have a leg of wiring harness in my trunk that is only partially connected. The five wires are in one wrapped part of the harness. The wire colors are one of each - yellow, red, green, brown and black. At some point someone got creative and cut the end off the harness and then jumpered some of the wires using an 8 pin bullet style flat connector. The bodged end of the harness was hidden (very well indeed) under the heater hose for the Webasto just behind the fuse block. The other end of the harness goes through the trunk pan (by itself and in a hole next to the main harness) and seems to go towards the rear of the car (maybe towards the floorboard relays). I know I can waste an afternoon tracing the wires out, but I thought if one of you wiring gurus might have a ready idea of what these wires serviced I could save myself some time. (also didn't see anything obvious on the wiring diagram) Thanks in advance for any help you can offer.
    Patrick
    67 911S
    Mar 2006
    Louisville KY
    Does the car or did the car have fog lights?
    Tony Proasi
    52 split window coupe
    It does have fog lights. They seem to work, but they are not wired in keeping with the wiring diagram. The wire colors don't match up for the fog light switch though. Maybe the cut wires are from the fuse block???
    Patrick
    67 911S
    Another Electrical Question
    In looking at the electrical diagram I noticed that one wire for the fog lights crosses over other wires at the fuse box. There is a white square where the two wires cross. What does the white box denote, if anything?
    Patrick
    67 911S
    That is an aftermarket harness for something, it's not part of the car. Trace the other end, I bet it's stereo gear.
    The white boxes don't mean anything, there is one on both ends of the wire to make it easier to trace on the diagram.
    Or it could be a relay for something__
    30
    85
    86
    87
    87a
    like that.
    Quote Originally Posted by pacarguy
    Post good pictures of it and I'm sure we can accurately tell you.
    -Allen-
  1. H4 wiring question
    By POS in forum Technical Info
    Last Post: 09-09-2012, 09:21 PM
  2. 71 Engine wiring Question
    By John912 in forum Technical Info
    Last Post: 11-10-2010, 04:32 AM
  3. simple wiring question for TTG...
    By Kaleid in forum Technical Info
    Last Post: 05-13-2008, 07:56 PM
  4. Wiring Question(s)
    By Paul Schooley in forum Technical Info
    Last Post: 02-19-2008, 10:55 AM
