Results 1 to 10 of 10
Thread: 69 turn signal switch, left turn works, right doesn't
    Guys,
    I took the 69 out yesterday and found that the turn signal works for left hand turns but I can not get the switch to move to signal a right hand turn. It feels as if something is jammed in the mechanism. For a righ hand turn the lever will not even move a millimeter off of dead center.
    This morning I took the switch off of the sterring column but can not find any evidence of a jammed part. Where should I be looking for binding parts?
    Possibly related information: prior to the failure I noticed that the self cancelling feature did not work. It was necessary for me to return the return signal lever to neutral following a turn.
    Thanks for the help
    John, card carrying member #322
    Looks like I answered my own question. I sprayed a bit of WD 40 on the face of the switch, wiped off the excess and found that movement was back to normal. After reassembling the plastic covers and installing the steering wheel, the turn signals work fine on both sides. Not sure about the self cancelling problem until I take a test drive.
    I'm never so dumb as when I'm trying to be smart
    Oh, I see you got it fixed, I thought maybe you had gotten a NASCAR switch
    Ed,
    Good to hear from you. Some times I impress even myself, although before I sprayed the WD 40 in there, it seemed to me that the switch was secured with a 19 MM lug nut. So I'm still not sure what the problem was. Oh well, I'll take one in the 'win' column and be happy.
    Now all I need to do is figure out what a NASCAR switch is. Is that sort of like a Bulgarian Anesthetic? Administered with a baseball bat?
    Seemed funny to me at the time......NASCAR....they only turn left!!!!
    Now you know why I don't make a living doing standup comedy, Leno, your job is safe!!!
    Ed
    Now that you have explained it, your comment made me smile this morning. Your mind obviously works at a much higher level than mine.
    On an unrelated subject: Will I be able to buy you a beer at the Charlotte Parade?
    Hey, you gonna be there, GREAT, look forward to meeting you and collecting on that drink!!!
    Ed,
    I'm not registered. Just going to be there as a visitor. We plan to arrive on Friday and leave on Monday. As the old Vaudeville act goes: "If you get there first, you draw a blue line. If I get there first, I'll rub it out."
    My cell is 513 325 8071
    John, sent you a P.M. but your box is full, time for some housecleaning!
    Ed,
    PM Box now cleaned out. I would have procrastinated on cleaning it out but I didn't get around to it.
  1. WTB left rear turn signal for 67
    By 1QuickS in forum Technical Info
    Last Post: 06-03-2011, 03:10 PM
  2. WTB: Left rear turn signal box for 67
    By Sacto S in forum For Sale: 911 Parts
    Last Post: 05-17-2006, 02:02 PM
