Thread: Taller Intake Manifold Question
    I changed out my stock intake manifolds (one was broken at the mounting holes to the engine) with taller ones (1 inch taller) that say REM on them. I 'think' they're PMO's but not sure. Regardless, I've noticed on the shakedown run that when I get on the throttle it's great but if I take my foot off the loud pedal the engine will die. I was under the belief that I wouldn't have to rejet the carbs for a taller intake manifold. Is this right? Or should I be looking for something else to be the culprit. It also runs kinda crappy at low rpms. Any advice is appreciated.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    My best advice would be to look for a vacuum leak or two between the manifolds and carbs and/or manifolds and heads.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Larry ljowdy's Avatar
    Nov 2006
    Ontario, Calif.
    The best method for finding vacuum leaks is via a can of carburetor cleaner. Spray at every connection (ie, manifold to head, carb to manifold, hoses, etc.
    I used to use ether and try to detect an increase in RPM's but found that carb cleaner causes the engine to stumble and is easier to detect..
    Carb cleaner sounds good. My buddy suggests a small propane torch (without the flame obviously). That should raise the rpms a bit if the propane gets sucked in to a leak. I'll try both. First I'm going to remove the air cleaner assy. and recheck tightness at all mounting points. I used all new gaskets and checked tightness 4 times before firing up the engine the first time. I'd like to use a torque wrench but it's difficult to use in some of those locations. Anyone know the torque specs for the carb/manifold and manifold/engine mounting points? Webers on top.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Nov 2006
    Ontario, Calif.
    I've also experimented with propane and as I said above, ether.. It's easier to detect a stumble in the idle with the carb cleaner than it is to detect a small increase in RPM's using propane or ether
  1. Intake Manifold Question???
    By garycox in forum Technical Info
    Last Post: 07-19-2017, 09:15 AM
  2. 2.0L Intake manifold Gasket
    By Norm01 in forum Technical Info
    Last Post: 03-08-2016, 12:27 PM
  3. '68 Intake Manifold - Finish?
    By GD727 in forum Technical Info
    Last Post: 04-23-2010, 03:19 AM
  4. WTB: pivot for intake manifold
    By preS in forum For Sale: 911 Parts
    Last Post: 04-06-2010, 09:45 AM
  5. Weber intake manifold question
    By Phoenix-MN in forum Technical Info
    Last Post: 10-16-2006, 09:11 AM
