Results 1 to 9 of 9
Thread: Steering shaft play normal?
    Member A_Alfa's Avatar
    Jul 2006
    Spain / Germany
    When I push/pull with boths hands strongly on the steering wheel of my 911E (momo prototipo + hub) in the driver vs instruments/gauges direction I notice a +-1milimeter (0,04 inch) play. Again it only does it if I push pull strong.
    Can that be considered normal?
    I have check the steering wheel bolt and it's tight to specified torque.
    Thanks. Arturo
    Early S Reg. #1263
    72´911E
    95´993
    02´986S
    No, probably not normal. Stock 911 hub takes a spring and a collar that fits into the steering column bearing.
    Momo hub I am not sure, you may just have to wrap with electrical tape to take up the slack, I have read that some have done that.
    Apr 2003
    Portland, OR
    Quote Originally Posted by Fritter
    FWIW, when I installed my Momo wheel and adapter, I moved the spring and bush to the base of the adapter with no problems. My wheel does mot move (improperly).
    Harry
    Member #789
    2009 MB C300
    You shouldn't resort to electrical tape to take up slack. Something is out of kilter in your setup. I've done wheels on cars for years and have never had this issue. I think it's time to look at "how it goes together" again.
    The spring should slide up onto the MOMO hub just like the stocker and apply pressure to the bushing. If the spring is inadvertently left out the wheel will be VERY sloppy.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Jul 2006
    Spain / Germany
    Thanks All. Will recheck installation again.
    Early S Reg. #1263
    72´911E
    95´993
    02´986S
    Hi,
    Porsche also used a support ring which sits under the spring. This is shown on the PET up and including 1969 cars. Across those years (up to 73), the shaft bearing and the spring are the same, so I am not sure why these were stopped being used. I fit support ring for all years and it does help, the reason being it has a lip which sits up against the bearing inner face and takes out some slack, the spring then helps hold the ring and thus steering tight.
    HTH
    Alan
    Jul 2006
    Spain / Germany
    Thanks Alan, good to hear from you.
    I will give it a try in I case cannot fix it with current instalation.
    cheers. Arturo
    Early S Reg. #1263
    72´911E
    95´993
    02´986S
    Apr 2003
    Portland, OR
    There is a pretty good discussion on this topic here: http://forums.pelicanparts.com/showt...eering+bushing
    The assembly should look like this:
    Harry
    Member #789
    2009 MB C300
    Apr 2003
    Portland, OR
    Factory part available again:
    Bushing Part#: 695.347.725.00.
    Spring Part#: 914 347 713 00
    Harry
    Member #789
    2009 MB C300
  1. Steering shaft bearing
    By rdelmendo in forum Technical Info
    Last Post: 02-16-2016, 06:17 AM
  2. Steering wheel shaft play. How much is normal?
    By ulrichd in forum Technical Info
    Last Post: 07-20-2014, 02:28 PM
  3. SWB Steering Rack, shaft up to the steering column
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-12-2012, 07:11 PM
  4. Ah how nice, no more play in my steering wheel!
    By berettafan in forum Technical Info
    Last Post: 04-02-2009, 09:44 AM
  5. steering shaft play
    By wit61 in forum Technical Info
    Last Post: 04-21-2003, 12:03 PM
