Results 1 to 7 of 7
Thread: Sunroof Screws
    Sunroof Screws
    Here is a crazy request! I'm trying to determine what kind of a screws I need for my sunroof. It is a screw that is used to hold the rear cable guides. There is one on each side. There a two that go vertical which I have but, the horizontal one is what I need. I'm just looking for the size, thread type, head type etc and I can go out and source one. I'm not sure if it should be shouldered, with washers, spring washers, etc. They are not shown on any parts drawings. Tried Stoddard and Parts Heaven and they didn't know what I was talking about.
    Mike
    Early 911S Registry #880
    356 Registry #30248
    1973 911S 2.7 RS spec
    1973 911T
    1964 356C twin plug
    1969 Z28
    bump
    anybody have any ideas?
    Mike
    356 Registry #30248
    1973 911T
    1964 356C twin plug
    1969 Z28
    Bump
    will try this bump one last time...
    not looking for the screws just info of what kind to look for.
    Mike
    356 Registry #30248
    1973 911T
    1964 356C twin plug
    1969 Z28
    Dec 2003
    West Los Angeles
    The cars I've worked on have had studs to mount the 'ears' of the rear cable guide. Maybe I'm not understanding the part you're describing...
    techweenie.com
    screws?
    A "stud" might make sense since these "screws" I think I'm looking for don't show on any PET drawings. The darn thing is I don't have another sunroof to look at. Anybody else with experience would be greatly appreciated ??? Thanks.
    Mike
    356 Registry #30248
    1973 911T
    1964 356C twin plug
    1969 Z28
    screwed
    Why not buy/borrow a set of metric taps & dies ( harbor frt has them for small $ , maybe $20.00. I have had a set for 20 years and if you are careful they do not brake). At any rate try the different taps and when one fits you have your size, thread pitch, and length.
    Bump
    Anybody have any more ideas???
    Mike
    356 Registry #30248
    1973 911T
    1964 356C twin plug
    1969 Z28
  1. H1 Screws
    By jaudette3 in forum Technical Info
    Last Post: 01-16-2013, 09:02 PM
  2. Replies: 13
    Last Post: 06-05-2011, 02:26 PM
  3. Visor Screws
    By aturboman in forum Technical Info
    Last Post: 07-02-2009, 06:10 AM
  4. Mystery screws
    By Max (SD) in forum General Info
    Last Post: 06-26-2008, 10:45 PM
  5. Air bleed screws
    By 72narrow in forum Technical Info
    Last Post: 10-10-2001, 03:57 AM
