Results 1 to 2 of 2
Thread: Heater Thermostat Question
    This may be a dumb question, but where exactly is the thermostat for the webasto heater located. I see that it goes into a wye pipe, but I dont see it. Do you have to remove the heater and access the piping going to the left side to find it?
    Patrick
    67 911S
    Try the hose that passes thru the trunk floor into the car behind the glovebox
  1. Thermostat question
    By PMNorris in forum Technical Info
    Last Post: 04-26-2014, 04:37 AM
  2. Webasto heater switch mounting question
    By 60surfer in forum Technical Info
    Last Post: 01-01-2013, 11:27 AM
  3. Early SWB floor heater slides question
    By Haasman in forum Technical Info
    Last Post: 10-10-2012, 09:43 AM
  4. Eliminating Heater& MFI Thermostat
    By bliebler in forum Technical Info
    Last Post: 05-04-2011, 06:59 AM
  5. Webasco aux. heater question
    By super9064 in forum Technical Info
    Last Post: 12-03-2007, 07:04 PM
