Trying to workout some wiring bugs and I cannot understand what is causing my oil pressure gauge to peg to the top when I start the car. Fuel gauge is not reading either.
This novice welcomes all suggestions and ideas!
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
It's sounds like you might have disconnected the ground wire for those gauges by accident. Which wires were you troubleshooting, where the gauges are or in the engine compartment? It's appears to be a real easy fix though, just recheck the ground wires and try it again.
Let us know what you find.
Tim G
Early S Reg #1017
RGruppe #663
73 911T 3.2
00 Ducati 996 Track Rat
01 Ducati S4 Monster
Does it start to function after the car is warmed up?
Nope. It pegs to the top as soon as the car starts.Originally Posted by Flieger
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
+1 on the grounding, then.
My fuel gauge would not work and the oil level gauge would flutter way too much to be normal sloshing in the tank and differences in engine speed.
I found that there was no ground for the oil level sender (must have been overlooked during fiberglass fender conversion). I found a different bolt to the chassis to ground to and put a wire and connector on the sender. Both the fuel and oil level gauges then worked very well.
Make sure to check fuses for corrosion, as always.
Hope this helps
I'll do some checking.
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
