Results 1 to 9 of 9
Thread: Center Dash Speaker replacement
    I need to replace my tired center dash speaker on my 73RS. Does anyone have a good one that you are willing to part with or know of a source for a replacement speaker? I can't find any references to original stock equipment sources or replacements here or on the Pelican forum.
    Lee Giannone (Eastern PA)
    Early S Registry #808
    1960 356 Super 90 Roadster
    1966 911 2.0L Vintage Racecar
    1972 RSR Tribute
    1975 Privateer RSR (Diego Febles)
    1997 993 C2S Factory Aero
    1984 962-102 (Coca-Cola / Akin)
    1973 RS Carrera #911 360 1018 (2008 Parade Grand Champion) Sold
    1968 911L #11810414 FIA Group 2 Rallye Car (Destroyed in Fire '08)
    1975 RSR #911 560 9114 (Sold)
    1975 RSR #911 560 9122 (Sold)
    Senior Member Macroni's Avatar
    Nov 2006
    Philadelphia PA
    Lee,
    I might have an extra. I will call you this morning.
    Luke
    86 Sport Purpose Carrera "O4"
    Replacement Speaker
    Lee do a search, There are several options. Even useing newer quality speakers.
    Regards, Bill B.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Replacement speakers
    Bill,
    Thanks. I did quite a bit of roaming around old posts and reviewing some of the options including the twin mounted speaker solution. I want to keep thing as original as possible, so I wanted to see if someone was manufacturing a replacement for the original or if there was an original out there in good shape that was new or used.
    We'll see what my friend "Macroni" Luke comes up with.
    1972 RSR Tribute
    I haveexcatly the same problem in RS #197 certainly can't locate a replacement down under
    I cut an exact template of the outisde of the original speaker in 3mm fibreboard and then using a jigsaw cut out the centre of the board to allow for the fitment of a 4" Pioneer speaker. Screwed it all back in as original
    Wires attached straight on and hey presto.
    I will search for an original speaker, in the mentime no one knows any different.
    If you find 2 I'll buy the second one for sure
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Radio Koenigs in Germany has a replacement unit with a higher capacity in stock. I bought one for mine, looks very nice, although not fitted yet. Check out here:
    http://www.koenigs-klassik-radios.de...23-27-0-0-0-0/
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Thumbs up Center dash speaker replacement
    Michael,
    Thanks. I'm sure others will be interested in seeing that this is available. I ordered one and I'll pass on how well it looks, fits, etc.
    1972 RSR Tribute
    Mine arrived yetserday its awesome, perfect reproduction for shape and sounds fin.
    Apparently mercedes used the same speaker so if you want an old working one maybe benz parts places also
    Clyde Boyer
    mine = which one?
  1. replacement of single dash speaker recommendations
    By cmcfaul in forum Technical Info
    Last Post: 04-20-2020, 02:57 PM
  2. Center dash speaker mod
    Last Post: 12-29-2006, 05:59 PM
