Thread: is there a list of trans codes + ratios ?
    Hi
    is there a list of 901 transmission codes and what gear rations they should have inside then originally ?
    and is there a code if it had a ZF diff from the factory ?
    thanks for the info
    Chuck
    PS.....and another list for 915 boxes ?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    thanks , that link was what I needed ,
    also anyway to tell if it has a ZF in it from the codes stamped on the case ?
    Chuck
    Just spin the output flanges or one of the tires if everything spins same direction you have a limited slip if not it's and open diff.
    Phil
  1. 71 901 transmission ratios from a T to an S?
    By Rino71 in forum Technical Info
    Last Post: 11-29-2012, 07:56 PM
  2. Anyone on here used these 901 gear ratios ?
    By andyjboy in forum Technical Info
    Last Post: 12-17-2009, 03:45 PM
  3. Gear Ratios For a SWB
    By jaudette3 in forum Technical Info
    Last Post: 01-07-2007, 07:41 PM
  4. Steering Ratios
    By RTincher in forum Technical Info
    Last Post: 08-28-2006, 07:03 AM
  5. 69S Transmission Ratios and Tranny Noises
    By JuanLopez in forum Technical Info
    Last Post: 11-21-2001, 06:37 AM
