Has anyone recovered the fixed map pocket on an early S? Here is a photo of why I need to:
I can handle the sewing to make the corner. The tricky part seems to be forming the vinyl to the complex curves and the bolt opening at the other end. Thinking a heat gun (gentle) might help. The factory apparently used contact cement in these areas.
cheers,
Michael
