Results 1 to 10 of 14
Thread: In Dash Blower Motor Failure
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    I'm getting power at the connection to the blower motor but she don't wanna hear it anymore. Has anyone ever repaired these motors and if so, what can I look for to fix it? I also found that the rubber seals around the flappers that are located in the housing are falling apart but I don't believe they can be replaced.
    Has anyone else repaired these items or do I simply have to replace the motor and housing?
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
    The blower motor is available after market from Bosch, I don't have the number here at home, but I 'll get it and post it later. As to the rubber around the valves I've never done that, but I don't see why it couldn't be done as a home project, probably way too much handwork for shop rate stuff.
    there is a thread on pelican re replacing the rubber foam parts
    Its easy to replace just the motor not the entire air box two screws from memory, 10 minute job
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Nov 2006
    Rhode Island
    Thanks for reply guys!
    I'll look for that thread on pelican about the rubber foam replacement. As for the motor, I wanted to see if it was just a matter of simply cleaning the contacts etc...
    Or maybe I'm just being a little cheap
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    Nov 2006
    Rhode Island
    Quote Originally Posted by edmayo
    Ed,
    the numbers that I have on the blower motor are:
    CPK 12V 13. 90. 4
    0 130 066 015
    I Googled "Bosch electric motors" and searched those numbers but I didn't get a match. Was I looking at the wrong site or should I simply order the motor with the fan thru pelican?
    Tim G.
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    Tim, the Bosch number I promised is 0 130 007 002. It will have a different brush setup than your old one, but it is the correct replacement, I have installed them so I know they work.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Blower Motor
    I had my local auto electric place repair my motor, it just need new brushes! 20 bucks
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Nov 2006
    Rhode Island
    Quote Originally Posted by Gumby
    This is exactly what I did last week Gumby! Before I order a new one I figured I'd try and have it repaired first so I dropped it off at a local electrical shop to see what they can do.
    If they can't fix it then I'll have it replaced
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
  1. FS: Blower Motor Cover, Original
    By J-P in forum For Sale: 911 Parts
    Last Post: 08-06-2013, 03:31 PM
  2. FS: Blower Motor Cover, Original
    By J-P in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
  3. WTB: Y-piece for front blower Motor RSR mount
    By Xavier PJB in forum For Sale: 911 Parts
    Last Post: 06-03-2013, 05:03 AM
  4. FS: Cardboard Blower Motor Cover
    Last Post: 05-02-2010, 08:33 AM
  5. WHB: Cardboard that covers blower motor 1971 911
    By mpgandco in forum For Sale: 911 Parts
    Last Post: 11-05-2008, 08:13 PM
