I have an early/SWB electrical panel, reported to be from a 67S. Experts.... please cast your eye(s) upon this and let me know what your verdict is.
regards,
al
regards,
al
Al Kosmal
the X-faktory
Current projects; 69-911.5
76S rat bastard---off to Germany
1970 914-4...off to Wisconsin
73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
66 912 ...off to France
71E 9111200979 ( gone to Paris..then to Corsica)
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Most everything looks like what I found on my '67 with the exception of the Bosch piece on the left end.
[SIGPIC][/SIGPIC]
1967 911S Coupe
1991 944S2 Coupe
Past projects:
1967 912 Coupe
1969 911T Coupe
1985.5 944 SR Coupe
It does look like a 67 panel. The bosch item on the upper left appears to be the size and shape of the inducer used to triger an early square wave tach with cdi. What markings are on it? tom
Tom
67S soft rear window
60 356 Cab
70 914-6 3.2 short stroke twin plug
05 Audi S4 Cabrio (commuter)
05 Audi Alroad (family driver)
Aprilia SR 50R (Sanibel scoot)
Al,
That is an SWB panel, no way to tell if it's for an S but there is no difference.
The good:
Original German bendix fuel pump with banjo fittings
Original ballast resistor
Original ballast resistor relay (mounted upside down)
Looks like an original Voltage Regulator, but can't tell, not a good enough photo.
The bad:
Wrong coil, that is a CDI coil. Someone was using this with a CDI system, hence the "intermediate unit" necessary to drive the low-impedance SWB tach off the coil. It says "einbau senkrecht klemmen unten" which means "install with contacts down" whoever put it there can't read German.
The terminal block for the positive wire is broken, these are NLA.
That is not the right ground wire, it should be brown, and the connectors are USA aftermarket with the blue insulation, not original German brass with rubber covering.
SWB cars did not use a fuel filter. You should use one, though.
The panel should be semigloss black with silver plated clips for the screws.
All in, I would say it's a good starting point for an SWB panel. See my thread called "Before There Was BHKZ" for all there is to know about this stuff.
Thanks for the info gents. sitting in my hotel room in chicago (tornado alley this week) Can't wait to get home and start the refurb on this early electrical panel.
Project #99 in an unending series.
regards,
al
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
