Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Solex Fuel pump rebuild - where to get kit?
    I hear that the 356C fuel pump rebuild kits have the necessary parts to rebuild the dual fuel pumps on 40P1 Solex equipped early 911s. The 911 needs two of them. It also appears that Stoddard carries these at $70/ea. Before I drop the coin, can anyone confirm, from experience, that this is the case?
    Thanks.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Sep 2006
    La Quinta
    Kenikh,
    I think the diaphram is different from the 356 one to the 911 one. The 911 ones have a long rods on them as compared to the 356 one. I think the gaskets are the same.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    Seattle WA
    call Emory, either Gary or Don Marks will know
    Nov 2002
    San Dimas, CA
    Nope, the 356C diaphragm is very, very different from the 911 tandem pump diaphragm. I have disassembled a 911 tandem pump and I briefly owned a 356C diaphragm. I'm certain.
    The two diaphragms are about the same diameter--the rubber parts look identical. The metal fittings are vastly different: the 911 tandem pump has a long metal prong. Here are drawings from the respective parts books.
    All is not lost, there are folks who make fuel pump diaphragms. You might want to contact:
    Jim Simpson
    O.D.D. Parts Repairs
    18853 Orange Ave.
    Sonoma, CA 95476
    http://www.oddparts.net/
    (707) 939-1457
    or
    Edward W. Fall
    Vintage Werks
    2125 East Commotion Drive
    Sandy, Utah 84093-1029
    http://www.vintagewerks.com
    (801) 944-9777
    You might also try Stefan Schleissing at http://www.classiccarseats.com/ (702) 353-7175 He once told me he could find parts for the tandem pumps in Europe.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Mar 2006
    Louisville KY
    Tony Proasi
    52 split window coupe
    Gary is the one who told me the 356 diaphragm will work. Then I came across posts to the contrary, which is why I posted this. I will check the links and get back to you all...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I just emailed Ed Fall. He offers full resto service and if he can do the pump, will solve all of my problems.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi Kenik,
    Please let us know how things go. This is great information for Solex owners. Anyone have comments on the VW parts that Tony found? From the picture the diaphragm looks right.
    Alan
    They are so cheap it may be worth buying one to test.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I know the diaphram used in a VW type3 1500 engine is the same part. A word of warning though, try to get a genuine (Old) peirburg one, the have EBBE printed on them. The old red type diaphram is bomb proof, where as the modern made black diaphrams don't last, they almost seem to get broken down by petrol bizzarely!
  1. MFI fuel pump rebuild
    By merbesfield in forum Technical Info
    Last Post: 02-04-2020, 07:33 PM
  2. fuel pump rebuild kits
    By speedo in forum Technical Info
    Last Post: 06-15-2014, 12:41 PM
  3. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  4. Help with solex PI 40 fuel pump set up
    By lars1965 in forum Technical Info
    Last Post: 08-23-2011, 06:33 AM
