Hi all, trying to id this headlight unit, I think it may be a sealed beam with a cibie spot built in behind a clear glass, any idea's?
cheers, Mike
Member#1664
1972 911 S/RSR to Martini Prototype specification
http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
Repro Hella 19 20 21 lenses are available as blanks (no markings).
_B
Sent from a pay phone
888888 eL, Oph'eL'ia
Instagram: werk_crew
www.werkcrew.com
www.werkcrew.tumblr.com
www.handofwinter.tumblr.com
Looks like Cibie is maked on the lens.
67 Normale, Old Rusty
67 R Inspired and on a Diet
73 T/ST Caged Beast
RGruppe #383
S Registry #739
Hi Mike, I agree with Raj, the headlamp in question is a 7" Cibie biode housed in a 65 to 68 SWB casing. There should be a few that pop up on Ebay UK once in a while but they are so pricey these days as the Biodes are de-riguer equipment for any Escort Mk1 RS 1600 restoration.
I'm looking for a pair of those light units if anybody knows of some.........
cheers, Mike
Member#1664
Let me ask about these lights.
The first is as shown on Randy Leffingwell's photo (last issue of Excellence) It this the Cibie Biode - dual bulb lamp? The small reflector is for low beam and the larger rear reflector is for the high beam? Is this correct?
Second is a H-4 Marchal IODE Codif 612 41203.
Both of these are 7" and will fit in behind the clear Hella SB19-20-21 glass. Are they both period correct?
Bob
Early S Reg #370
There is an alternative to the otherwise pricey Cibie biodes, they are the CONVEX Ampliluxes ( not the flat ones for $400 ). These lights are a tad larger than your standard 7" and is longer in the back. Will only fit in your Hella SB's if you ditch the retaining ring, fitting them inside the bowl is another story
There's a pair on Ebay now ( for a Ferrari Lusso ) but you want a pair without the ears though.
If you want a pic you may pm or email me @ joeybau59@yahoo.com
HTH
Raj, thanks so much for posting those pictures, really helpful.
Judging from the picture which shows the depth of the cibie biode unit, it looks like it might be a tight fit in the headlight bowl of the fender!
thanks, Mike
cheers, Mike
Member#1664
I bought a pair of lenses that are more flush than the H-4's I have from an independant VW shop for under $20. Looks more or less the same as the first pic's in the thread.
Marc
'69 Coupe in Pastel Blau
R#464
S#1390
