Thread: leaky solex carb
    leaky solex carb
    I had the 66' 911 idleing no problem.. but one of the carbs seem to be blocked as it want to start but leaks fuel.. Is there a moderate fix or does it involve full rebuild of that carb?
    kevin.
    Leaking from where?
    near the accelerator pump rod. pretty heavily.. may be something clogging somewhere ... float?
    kevin
    Nov 2002
    San Dimas, CA
    By "accelerator pump rod" do you mean the lever that comes out of the accelerator pump cover?
    If it's leaking from the accelerator pump cover the first thing I would expect is a torn accelerator pump diaphragm. That's easy to change: just remove four screws. There's been a lot of discussion about sources for pump diaphragms. It's easy to get a kit t do all 6 carburetors--you might be able to find a single diaphragm if you look hard enough.
    However, I wouldn't expect a failed accelerator pump to affect idling. It's job is to add a little fuel when you open the throttle. You can easily get the jet carrier out of the carb (two screws) and do a little work with carburetor cleaner and compressed air.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  1. FS: Solex Carb Set 40 PI EXCELLENT
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 10-21-2013, 10:51 AM
  2. WTB: Solex Carb Parts
    By rcnagel in forum For Sale: 911 Parts
    Last Post: 12-17-2011, 02:02 PM
  3. FS: Solex PI carb
    By typ901 in forum For Sale: 911 Parts
    Last Post: 05-18-2010, 06:51 AM
