Results 1 to 10 of 10
Thread: Short Gears
    Jun 2003
    Bend, Oregon
    Short Gears
    I bought a 901 5-speed from someone on this board with A-F-M-S-X short gears and installed it into my '67 SWB. (BTW, short gears are *really* fun). Can anyone tell me if this gear set has a name, such as the term "airport gears" used in 356 circles? Could this be a standardizzed set such as "Hillclimb" ratios (901/52) or "Nurburgring" ratios (901/51)? Or just a custom build?
    They sure work great at Infineon.
    JohnA
    Gear ratios and names:
    Jun 2003
    Bend, Oregon
    Thanks, Flieger. It appears I have a 902/1. Is this what are called airport gears?
    JohnA
    I think "airport" gears are 901/52
    Mar 2006
    Louisville KY
    The 902/1 was a standard 5 speed gear box. It really is a great match for a early 911 engine.
    Tony Proasi
    52 split window coupe
    Since when are AFMSX short gears? AFMSX and AFMSZ are pretty much box stock on 90% of 901 longhoods. AFKQX, AEINS, AFJOT...those are short gears.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Jun 2003
    Bend, Oregon
    Quote Originally Posted by kenikh
    Since when are AFMSX short gears? AFKQX, AEINS, AFJOT...those are short gears.
    Whew! Those are short. I think they would be way too short for my car, running 15" 225/50's. My configuration sets up just right for PIR and Infineon - and around Central Oregon.
    Thanks for everyone's input.
    Cheers,
    JohnA
    IMHO, AFMSX is a nice compromise. It's what the factory installed on the ear althoug the X 5th is not very tall for highway use. I'd prefer something a bit longer but as a good friend pointed out; "When is the last time you drove your car on the highway?"
    He had me there.
    And here I sit with a 904 mainshaft + E, K, Q, V
    Best,
    Tom
    Early S Registry #235
    rgruppe #111
    Quote Originally Posted by sithot
    He had me there.
    Best,
    Tom
    Great gears! I pussed out and did AFKQX (heavily considered the V). After several thousand seat miles on this combo, I think AFKQX is the box that Porsche should have put in these cars...it still has great freeway manners. The Q to V split, though, is absolutely electric and still tolerable on the freeway, where the 'S' 5th combos are not.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    My dad had the airport gears in his car, really short but a rocket- Once they got rid of the 60 series race tires we switched him to KA,Q,V. Its a good mix.
    I'm switching my race car back to B,GA,KA,Q,V - from B,GA,M,S,X. Some tracks I do not shift into 5th, or it is right on the edge of shifting. The car will be much quicker.
    I will miss the X gear for Cal Speedway. I will just run bigger wheels/tires or go for a "W" gear instead.
  1. SWB Short Gears
    By jaudette3 in forum Technical Info
    Last Post: 04-19-2010, 07:20 PM
  2. FS: Short gears for 901 or 911
    By kenikh in forum For Sale: 911 Parts
    Last Post: 10-29-2008, 01:04 PM
  3. Short Gears for your 911!!! Ebay
    By pastel2020 in forum For Sale: 911 Parts
    Last Post: 04-05-2008, 12:21 PM
  4. Short Gears for your 911..!!!!!!!!!!!!
    Last Post: 03-03-2008, 12:54 PM
  5. 901 gears
    By preS in forum Technical Info
    Last Post: 10-16-2005, 05:23 PM
