Thread: Koni Paint Color?
    Koni Paint Color?
    I'm Looking To Buy The Red/orange Koni Paint.stoddard Used To Have It Years Ago.any Ideas?
    Thanks David.
    David,
    On a Ferrari site some recommended Plastikote T-31 Bright Orange... I've never tried it.
    I have always used the reddest (lots of variation) example of 'Chevy (GM) Engine Orange' spray paint I could find.....
    Hope this helps,
    Cheers
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Quote Originally Posted by Chuck Miller
    Same here... I'll add:
    Anyone who is underneath your car critiquing your "orange" is fair game.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    I have asked Koni:
    The color is 'RAL 2002'
    This is a German color code, but I think it is used worldwide. Interestingly the color is called 'Blutorange'.
    See here for the RAL system:
    http://www.ral-digital.de/deutsch/ralclassic_namen.htm
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Michael,
    Thanks for the correct info...
    A practical solution might be to send for the RAL chart, hopefully their chart will be done with real 'spray out chips'. Then pick up a Ppg 'Fleet Chart' from your local auto paint supplier. The fleet charts are comprised of most the national trucking fleets and all of their non-metallic colors. Then you compare the RAL #2002 with a chip in the fleet chart and the auto paint dealer can mix it for you in any type and quantity you want.....
    I've been using my chart for over 25 years......
    BTW- I punched the holes...
    Hope this helps,
    Cheers
  1. Early Koni color
    By speedo in forum General Info
    Last Post: 09-29-2022, 05:33 AM
  2. Koni color
    By tomlu in forum Technical Info
    Last Post: 03-22-2013, 08:07 AM
  3. Paint Color
    By Jeff Sepahpour in forum Technical Info
    Last Post: 05-22-2010, 08:39 AM
  4. koni color code
    By egbert in forum Technical Info
    Last Post: 05-22-2009, 09:43 AM
